I have got several avi movies and have just purchased a vcd compatible dvd player, I have the panasonic mpeg encoder 2.51 how do I go about getting the best possible VCD copy when the avi file{ size 352 x 288, 20.000 Frames/Sec audio 24000hz stereo} is 20000 frames p/sand then how do i go about copying it to cd i have both nero and cdrwin{i pefer cdrwin)
any help would be great
Don't much about the Panasonic Encoder, I use Tmpgenc, which can be downloaded for free.
In Tmpgenc, choose the VCD or SVCD templates, you will be able to generate compliant Mpegs. I prefer using Nero to burn them. -
It all depends on whether you want to convert to PAL (Europe), or NTSC (USA)...
Where are you in the world? -
I have tryed tmpge but 4 the file in question it says that it is can not open or unsuported but it works in panasonic so thats why i use it
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
