I have an ISO of a complete movie with menu. Since the movie will only occupy about half of the DVD, I want to add some vobs of another movie. How can I do that without losing the menu functions of the ISO? Thanks.
extract the video_ts and and join and reauthor to new dvd with dvdremake pro, it will keep the original menus
no easy free solution.
or if you just want to add the vobs as dvd data files(not playable on most dvd players) extract the video_ts and burn to a dvd-video with a burning tool( https://www.videohelp.com/author#3;25 ) and drag the vob files to the root or some other folder. the menu will work. -
This "data" thing might work for me because I already converted the said vob to Divx but a bit confused on the process of putting it on the root. I will extract the ISO and will put the AVI in the root folder? If that's the case, can I use Nero or Roxio using just regular DVD creation? Thanks for the help.Originally Posted by Baldrick
Convert ISO to VOB
By larrytxeast in forum Video ConversionReplies: 6Last Post: 23rd Jul 2010, 01:20 -
VOB to ISO
By joshua4 in forum Newbie / General discussionsReplies: 6Last Post: 5th Oct 2009, 07:06 -
Creating ISO from VOB's
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2009, 14:36 -
Iso and VOB conversion
By willmoodom in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2007, 02:34 -
vob to iso?
By jree1 in forum Video ConversionReplies: 8Last Post: 20th May 2007, 12:12
