Are there different types of Svideo cables that work better than others? The futureshop loser was trying to sell me on some 100 dollar monster svideo cables. I laughed at him at first and then thought i should do some fact finding of my own. Your opinions?
Results 1 to 11 of 11
Other than basic build quality (sturdiness, wire gauge etc.), pretty much any cable will work as good as another
"Art is making something out of nothing and selling it." - Frank Zappa -
Monster is a bunch of BS. Don't buy into their marketing but also don't buy cheap 99 cent cables.
I agree that Monster is overrated. However, I once bought a $15.00 HDMI cable online and had to send it back, because of a loose connection. Don't go *too* cheap.
yea, i'd say go a little above mid range to be on the safe side...monster cable is REDICULOUSLY overpriced...yes, it does work awesome, but so does the cabling thats one notch below it that costs 1/4 the price.....even stuff like radio shack brand gold plated cable works pretty good. Myself, i use around a 30 dollar s-video cable that i picked up one day on a spending rampage at best buy...spent something like 2500 bux that day, so i just tacked on the cable like most people tack on a soda or candy or something like that....spent WAY too much there that day.
Yeah, after the HDMI cable fiasco, I bought a gold-plated HDMI cable from my local cable company for $50.00. Circuit City wanted about $100.00 to $120.00 for a Monster HDMI cable.
The one I got from my cable company was twice as long, too. -
Short, thick, and moderately priced. Have seen no visible difference among cable except for the absolute cheapest POS was slightly worse.
Never got a chance to test Monster s-video, but I agree that it's unlikely that they are better than more moderately priced cables.
https://forum.videohelp.com/viewtopic.php?t=279561&start=0&postdays=0&postorder=asc&highlight=cable -
Just get any S-VIDEO cable and it will VERY LIKELY work perfectly. The reason for this: the signal out of a DVD player is quite robust and a bit of problems on the way to the TV will not be significant.
The only times where you really need very high quality cables are:
a) when the signal is very weak, so you do not want added noise or losses
b) when the signal is *VERY STRONG* so that signal reflections can damage your devices.
Neither case is true for the application you have in mind (connecting a DVD player to a TV).
(BTW: I do have a PhD in Physics...) 8)Viva Linux!
Is using S-Video cable better than using RCA cables to capture video?
By snafubaby in forum Capturing and VCRReplies: 21Last Post: 7th May 2020, 09:16 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 01:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 21:03 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 09:38 -
RCA cables or S-video?
By effects in forum RestorationReplies: 3Last Post: 10th Jul 2007, 07:03
