    Dec 2001
    Dallas, Texas
    Anyone know where to get the MP4S codec, so I can open these asf files I have in vdub 1.3c?
  2. this needs to be bumped because i have the same problem
    Dec 2001
    Dallas, Texas
    I've sort of found a work around.
    I played the asf file in media player, and with total recorder, I recorded the audio.
    With TMPG, I took the asf file, and converted it to m1v (video only mpg, no audio)
    then in vdub, I opened up the m1v and then opened up the wav file I made with total recorder, and got them in to vdub.
    Hope it works for you!
  4. sounds cool, i'll have to give that a try.
  5. There is a much easier way and this is by converting it to an avi (this does not need recompression and takes just a few minutes)
    There are several tools that can do this the one im familiar with is asftools
    I don't know if you can download it here but u can get it at http://www.divx-digest.com in the downloads section
    Dec 2001
    Dallas, Texas
    I have asftools .. When I convert the asf to avi with it (trying both of the framerate options) it cannot be played in media player. Gives me an unknown error.
    Maybe I used it wrong.
