For some reason, when I tried backing up Wedding Crashers, the output file size was 3.9 gb and not the standard 4.5 gb. Anyone have any idea why the output file doesn't fit an entire dvd?![]()
I'm using CCE Basic, Full Backup and Steal Space from Extras (25%).
Theres no option in DVD-RB to do that. you would have to do it manually by changing the target sector size in the Rebuilder.ini file.
Add a command like:
Targersector=22640000
anywhere between [options] and [paths]
see:
https://forum.videohelp.com/viewtopic.php?t=284011&highlight=cce -
I recently did a boxset - four disks, all around the same size. 2 went without a problem, the other two DVD RB tried to squeeze down to 3.2GB. Could not determine a reason for this, so I put it down to a bug and used Shrink instead. The difference in results is, of course, blindingly obvious, but I could not get DVD RB to do the right thing, despite a number of attempts.
Read my blog here.
Thanks guys. I appreciate your help and will try changing the targetsector.
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 08:04 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 07:54 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 03:29 -
Video Conversion - output file size
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2008, 08:28 -
Controlling CCE's output file size.
By astrocity20 in forum DVD RippingReplies: 24Last Post: 13th Dec 2007, 23:32
