  1. Hi all,
    Apologies if this has been covered before, I couldn't find any ref. to it, but searching for things like 'MPEG2', 'wrong' and 'size' brings up many many results (not relating to my problem)?!
    Essentially, I have a Nova-T USB that I'm using to record digital tv using Showshifter. Mostly it's good, but some channels it seems to record at 544*576, but the files are reported (by AVOCodec for example) as 2.21:1. I have read that this is a genuine DVB resolution, but I don't get where the aspect ration figure comes from?!
    So anyway, my main question is, is it possible to somehow resize these files to a standard dvd resolution, say 720*576.
    Thanks in advance, and again, apologies if these has been covered many times - if anyone can point me at an appropriate thread I'll be very grateful.
    Cheers,
    Toby
  2. PS I meant to say, the files appear widescreen in WMP, NOT as square as the resolution would seem to suggest.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    2.21:1 is a widescreen format...the image is 2.21 times as wide as it is tall. Although I expect it is closer to 1.85:1
    It could be like a half D1 resolution, where the 544 is doubled during playback..so you have a resolution of 1088x576.
    Google is your Friend
    Apr 2004
    Miskatonic U
    I get 1.89:1. Try a resize to 720 x 560, with letterboxing out to 576. Encode as 16:9 and see what it looks like.
    Read my blog here.
  5. Hi,
    The 544 x 576i, Aspect Ratio 4:3 is broadcasting in France 2, France 3, France 4, France 5, ARTE and LCP (R1 multiplexer), you can refer to the following links :
    http://morin80s.free.fr/TSReader/051202_R1.htm
    http://morin80s.free.fr/TSReader/051201_R4.htm
    http://morin80s.free.fr/TSReader/051202_R6.htm
    http://morin80s.free.fr/TSReader/?M=D
