will this ver of nero burn dl? i used dvd decrypter to make an iso of a dl movie and want to burn to dl disc. when i try to burn with nero it shows the space on my disc up to 4.5 gig ok then after that it shows red.like i dont have enough space on disc.with the price of dl media i dont want any coasters if i can help it.i have the sony DRU-800A with updated firmware.
Sonic RecordNow Max seems to be the program most likely to produce a compliant DVD disc. Nero seems to be least likely to give good DL burns from the responses I've seen here.
why don't you burn it to a dl disk with dvddecrypter ... as you have ripped it in iso mode with dvddecrypter you can burn it back with dvddecrypter ... mode>iso>write
course it can.version 3.5.4.0
or you could use his new burning one,imgburn.
and if that cant do it(which it can),then the disc you used was a bad one,just like the one you used.
make sure the firmware on the writer is updated,and the programme you use is too,that version of nero is well old.and you could buy better media,verbatim for example,are the best for dual layer.
dvddecrypter - ISO read ISO write.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Burning to dual Layer discs
By Mastablastacious in forum DVD RippingReplies: 19Last Post: 5th Feb 2008, 18:50 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 04:16 -
Getting I/O Errors While Burning Dual Layer Discs
By VanCity in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2007, 23:35
