I have solved the problem myself, keep the post for furture refference if u want
What I did was remove the last cell (chapter) in Celltimes.txt and then it worked fine, didnt give me any errors this time.
--------------Original Message--------------
Hi I was hopeing to get some help here about my problem (sorry if it's the wrong place I am posting this)
Okay so here is what I was trying to do,
I had a dvd that I wanted to add some subtitles to, I used one of your guides (They have worked many times before for me with no problem).
Started by ripping the files from the DVD to harddisc drive, using dvddecrypter then I demuxed the movie file, using PGCDemux. No problems yet.
I syncronised the subtitles I wanted to add in SubtitleCreator, worked fine and seemed in sync.
Now I was going to work with MuxMan, I set the settings that I was used to do (like it said in the guide), like I said it has worked for me many times before.
Then I hit the "Start" button and it started, when it was nearly done it came with this "Error"
Can anyone tell me what is wrong?
Alittle info about the DVD:
Dusk Till Dawn 3, NTSC
Original files were:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_0.VOB
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
VTS_02_0.BUP
VTS_02_0.IFO
VTS_02_0.VOB
VTS_02_1.VOB
The main movie file were as usal VTS_01_1.VOB.
The guide I was using and have used alot of times is the one from bluedha, thanks alot for making the guide, it's great.
