has anyone figured out how to use CCE SP 2.50 with Premiere 6? I have some DV AVIs that i'm merging together with premiere, and i'd like to encode the whole thing with cce for DVD target. I tried to frameserve with the new avisynth premiere plugin, but cce gets to the second pass, and says something about the checksums of the source file not matchhing.
I tried to use the plugin, but as many of you know, the CCE 2.5 plugin doesn't work with premiere 6. Has anyone figured out a way to do this?
I'd consider using premiere 5.1 (since i've heard that works) but I don't even know if it will handle DV.
Thanks in advance, and any responses are appreciated.
Dan
dleehr@engin.umich.edu
I've tried cce 2.51 and 2.62, and could never do 2 or more vbr passes. Only cbr.
I would like to know what's the trick, too.
Best AviSynth plugin for deinterlacing? (general consensus) ...
By takearushfan in forum Video ConversionReplies: 5Last Post: 29th Apr 2011, 00:59 -
SupTitle: an AviSynth PGS (.SUP) Subtitle Plugin
By ZachSaw in forum SubtitleReplies: 6Last Post: 11th Feb 2011, 13:03 -
Which Avisynth deinterlace plugin provides the best result?
By Mdoodm1000 in forum Video ConversionReplies: 7Last Post: 21st Jun 2010, 19:41 -
Some cool Avisynth effects from EffectsMany plugin.
By racer-x in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:33 -
New Avisynth Plugin for Ffmpeg Compatible sources
By Soopafresh in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 19:49
