Hi:
I have a Sony RDR GX7 recorder that "seems" to be working fine. (Have it for two years with no problems).
I recently bought a GO Video DP 8440 (portable) for it's multi-format playback capability. Again, it seems to work fine when I play regular DVD movies. There's a problem with "home recordings" though.
Am I missing a step (or other device) which is preventing me from playing my recorded DVD from the RDR GX7 to the 8440?
All I'm trying to do is to record on either a -RW or +RW to play on the portable. I make sure that I finalize the disc but I keep getting a "wrong disc" message on the 8440. Should I also be considering the disc manufacturer?
Thanks (from a Newbie with a capital "N")
Wrong Disc, Normally means the player doesn't like that brand of Media. Try a better brand like Tanyo Yuden's and see if that helps. Some players are just more picky with media than others.
have you tried other -rw/+rw media?
can you play +r/-r that you burned with the recorder ?
BD player + HDD recorder
By jumpjack in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Jan 2012, 02:56 -
Mac DVD player missing
By nic2k4 in forum MacReplies: 8Last Post: 31st May 2010, 12:33 -
LG RH2T80 DVD Recorder DVD slide is possessed! Missing Darcy
By Darcy in forum DVD & Blu-ray RecordersReplies: 2Last Post: 16th Aug 2009, 16:00 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 10:49 -
Subtitles missing when played on DVD Player
By bmwr51 in forum SubtitleReplies: 10Last Post: 18th Apr 2008, 13:10
