Hi,
I have a Sharp DV-SR45U DVD recorder.
and it is not Finalizing the DVDs.
Does anyone have a hack/fix/patch for this unit?
Thanks.
That sharp dvd player should finalize your dvds.Have you gone into setup and clicked on finalize disc.On the remote setup button click it go to disc setup and you will see finalize .I had the same machine and loved it.The editing on that unit is the best.Even recording television in the lp mode is great.Another reason your disc may not be finalizing is your using dvd-r and are in the vr mode.
Sharp lc-40lb700x
By Margot in forum Newbie / General discussionsReplies: 0Last Post: 8th Jun 2010, 06:16 -
Sharp DV-RW370
By alduz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Mar 2010, 03:24 -
sharp dv-sv90
By tatusik in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Mar 2008, 12:02 -
Component overly sharp?
By NES_Master in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Oct 2007, 02:15 -
Multiregion for Sharp DV-SV90S
By PhyRo in forum DVD & Blu-ray PlayersReplies: 13Last Post: 12th Jun 2007, 13:12
