I have captured from Digital 8 camera thru firewire via WinDV to HD.
Then I used GSpot to check captured file details...
720 x 576 PAL DV
Then loaded avi into FitCD to get Avysnth script for CCE 267
Here is the script:
# -= AviSynth v2.5.6.0 script by FitCD v1.2.8 =-
AVISource("J:\capture\schubert\schubert.00-11-27_14-40.00.avi",pixel_type="YUY2")
SeparateFields()
LanczosResize(688,208,0,35,720,218).Weave()
AddBorders(16,80,16,80)
Trim(100,1000).FadeOut(150)
ConvertToYUY2(interlaced=true) # For VirtualDub or CCE
Then dropped this into CCE 267
only change to CCE settings was to change from 'ZigZgag' to 'alternate'
and deselect 'progressive'
and change flat area priority to 28
Played out put with PowerDVD ...getting jittery video
short jitters ...not jerks
its not interlacing lines...ie jaggies.... but slight jittering
I changed output file to mpg
and burnt to DVD...for testing on TV
Still same on TV
Is this "weave" setting in the Avisynth script causing this jttery output
or is there another field issue I havent noticed...????
Appreciate any help
Edit:----I had the source as YUY2...in FITCD
removed that...and redid encode
output in Powerdvd still looks jittery
Any thoughts or suggestions???
Results 1 to 9 of 9
I went back and looked at FitCD settings
it has a bff->tff setting ...or tick box
I ticked it and output another avisynth script...for CCE
did short encode with CCE...
played mpg with PowerDVD
...DAHDAH!
It looks like it fixed the jittery video
Its been a while since I have played with DV
Thanks...Abond...for future reference! -
To save the time you can use restream directly loading in it the mpv output from CCE. On the left middle part you will see that top field first is marked. Unmark it and click write. It will write new file name.0.mpv. Play it to see if the problem disappear.
For avisynth
AssumeBFF()
Separatefields()
But you must take in mind that CCE encodes always top field first. If you want to reverse the field order (I think) there is something like Offset line setting in CCE. This will delete the top scanline of the video making the bottom field to be top field and CCE will encode top field first (TFF).
If you want to preserve everything use HC encoder. -
Thanks...Abond
I hadnt done the whole DV file ...just doing test short ones as mentioned
...Thanks for the avisynth code change ...
will use that in future scripts
I have another 6 DV tapes to do
I noticed that field in CCE....thought it may have some relevance
but am always nervous changing settings in CCE
that it is also going into the memory bank..if any other problems
like this occur...
Do you use prefer HC encoder ??
or is this just a suggestion to fix the CCE top field problem? -
Well, I wouldn't say this is a problem with CCE, simply this is how the encoder works. Usually I preffer HC for low bitrate encodings at best mode. Though I really don't know how it performs with interlaced material.
I am making relatively rare DV conversions. There was something strange with avisynth field orders and CCE, but I could not remind what it was exactly. Anyway, try samples with different settings to check it. Well, good luck. -
yep..restream saves me a ton of time when i goof up and accidentally encode in the wrong field order. Takes care of the mix-up real quick!
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 06:11 -
DVD To Xvid - jittery, please help?
By kpoman in forum Video ConversionReplies: 5Last Post: 25th May 2010, 17:59 -
jittery slow motion scenes
By Dr_Layne in forum Capturing and VCRReplies: 1Last Post: 25th Aug 2007, 19:36 -
Convert avi to Dvd and Burn. Jittery video!
By Ragebflame in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 17:06 -
Jerky, Jittery DVD
By leng in forum Newbie / General discussionsReplies: 18Last Post: 24th Jun 2007, 10:15
