I am finding that after encoding with Tmpgenc (when producing VCD/SVCD's) the output video is fine, but the audio output just seems to have a rather low quality sound to it, it could be described as 'tinny'
Is there any way around this? perhaps using another encoder for the audio stream? if so, would there be issues with sync problems etc?
Results 1 to 10 of 10
Thats good to know, which products do you use mate?Originally Posted by guns1inger
I use Vegas for 5.1 AC3, and sound forge for 2 channel ac3.
If you are on a budget, ffmpeggui does a good job for AC3.Read my blog here.
Am I correct in thinking that AC3 cant be used on VCD/SVCD'S though?Originally Posted by guns1inger
I would think it sounds like a bad Sample Rate Conversion.
If boing decides to try toolame as an external audio encoder he might as well try SSRC at the same time, as a external Sample Rate Converter.
It's too bad that ffmpeg can't be used with TMPGEnc in this manner. I've tried to trick TMPGEnc into using ffmpeg.exe as an external *.AC3 encoder with no luck at all. It's too bad there isn't a go-between application telling TMPGEnc it was encoding *.MP2 stream, while actually encoding to *.AC3. (of course this isn't really a concern of someone encoding to VCD/SVCD)
There's a mini-guide for configuring TMPGEnc Free or TMPGEnc Plus to use toolame and/or SSRC here:
https://forum.videohelp.com/viewtopic.php?p=1396458#1396458If in doubt, Google it. -
Cheers guys, that seems pretty copmprehensive, I will crack on and give them a go
I would make your life "easy" and just use the toolame and SSRC plug-ins for TMPGEnc Plus.Originally Posted by jimmalenko
I've used them before and it's really easy to set up and the audio quality this way should be A-OK
Working to clean-up crappy DVD source, any suggestions appreciated.
By dragonkeeper in forum Video ConversionReplies: 10Last Post: 6th Oct 2011, 10:34 -
Raw HD Videos Look Great, Crappy After Rendering in Sony Vegas HD 9.0
By GonzoSauce in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2010, 17:39 -
Ripping audio always leaves me with crappy quality
By Nintendo Fan in forum AudioReplies: 20Last Post: 22nd Mar 2010, 19:51 -
Why am I getting crappy DVD encoding? (interlace problems, etc)
By timmus in forum Authoring (DVD)Replies: 15Last Post: 14th Apr 2008, 10:23 -
Sliders crappy packaging.
By gadgetguy in forum Off topicReplies: 1Last Post: 11th Jul 2007, 00:10
