Can someone give me all of the links to where i can download all the binaries and other software i need to convert real media?
ok i think i have everything i need... wen i try to encode a 5 sec test clip with these settings
it says finished but wen i open it all i see is a white screen without picture or sound
and my progress information says this:
any idea wat i am doing wrong?Encoding started on Thu Jan 5 23:28:24 CST 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
init_freetype
get_path('font/font.desc') -> '/Users/Travis/.mplayer/font/font.desc'
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
[file] File size is 112225204 bytes
STREAM: [file] /Users/Travis/Desktop/Arrival.rmvb
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
success: format: 0 data: 0x0 - 0x6b06bb4
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for REAL
REAL file format detected.
real: Header size: 18
real: Header object version: 1
real: File version: 0
Chunk: PORP (504f5250) (size: 0x32, offset: 0x12)
First index chunk offset: 0x6ad288e
First data chunk offset: 0x3f4
Flags (9): [save allowed]
Chunk: TNOC (544e4f43) (size: 0x40, offset: 0x44)
Chunk: RPDM (5250444d) (size: 0xa2, offset: 0x84)
Found new stream (id: 0)
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
==> Found audio stream: 0
Found audio stream!
version: 5
header size: 68
frame_size: 371
sub_packet_size: 371
FAAD: compressed input bitrate missing, assuming 128kbit/s!
======= WAVE Format =======
Format Tag: 20557 (0x504D)
Channels: 2
Samplerate: 44100
avg byte/sec: 64000
Block align: 371
bits/sample: 16
cbSize: 0
### skipping 0 bytes of codec info
Chunk: RPDM (5250444d) (size: 0x70, offset: 0x126)
Found new stream (id: 1)
Stream description: Video Stream
Stream mimetype: video/x-pn-realvideo
==> Found video stream: 1
video fourcc: 04VR (30345652)
H.263 ID: 40008000
unknown id: 40008000
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): image not found
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
4d) (size: 0x254, offset: 0x196)
Found new stream (id: 2)
Stream mimetype: logical-fileinfo
Got a logical-fileinfo chunk
### skipping 534 bytes of codec info
Chunk: ATAD (41544144) (size: 0x6ad24a4, offset: 0x3ea)
Packets in file: 155242
Reading index table from index chunk (112011406)
entries: 14303
stream_id: 0
next_header_pos: 112211668
Reading index table from index chunk (112211668)
entries: 964
stream_id: 1
next_header_pos: 112225184
Reading index table from index chunk (112225184)
entries: 0
stream_id: 2
next_header_pos: 0
Auto-selected RM video ID = 1
VIDEO: 04VR [40008000,01481020] 396x224 (aspect 0.00) 30.00 fps
VIDEO: [RV40] 396x224 24bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:11 fourcc:0x30345652 size:396x224 fps:30.00 ftime:=0.0333
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
dec_audio: Allocating 4608 bytes for input buffer.
dec_audio: Allocating 49152 + 65536 = 114688 bytes for output buffer.
FAAD: Decoder init done (0Bytes)!
FAAD: Negotiated samplerate: 44100Hz channels: 2
AUDIO: 44100 Hz, 2 ch, s16be, 128.0 kbit/9.07% (ratio: 16000->176400)
Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=320 h=176]
SwScale params: 320 x 176 (-1=no scaling)
Opening video decoder: [realvid] RealVideo decoder
realvideo codec id: 0x40008000 sub-id: 0x01481020
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
Read the RealVideo section of the DOCS!
VDecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
INFO: RealVideo codec init OK!
Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
Forcing output fourcc to 58564944 [XVID]
Building audio filter chain for 44100Hz/2ch/s16be -> 48000Hz/0ch/s8...
[libaf] Adding filter dummy
[dummy] Was reinitialized: 44100Hz/2ch/s16be
[libaf] Adding filter lavcresample
[dummy] Was reinitialized: 48000Hz/2ch/s16be
Building audio filter chain for 44100Hz/2ch/s16be -> 48000Hz/2ch/s16be...
[libaf] Reallocating memory in module lavcresample, old len = 0, new len = 4612
VDec: vo config request - 396 x 224 (preferred colorspace: Planar I420)
VDec: using Planar I420 as output csp (no 0)
Movie-Aspect is 1.77:1 - prescaling to correct movie aspect.
VO Config (396x224->396x224,flags=0,'MPlayer',0x30323449)
REQ: flags=0x441 req=0x0
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
SwScaler: using FAST_BILINEAR C scaler for horizontal scaling
SwScaler: using n-tap C scaler for vertical scaling (YV12 like)
SwScaler: 396x224 -> 320x176
REQ: flags=0x401 req=0x0
videocodec: libavcodec (320x176 fourcc=58564944 [XVID])
*** [scale] Exporting mp_image_t, 396x224x12bpp YUV planar, 133056 bytes
*** [lavc] Allocating mp_image_t, 320x176x12bpp YUV planar, 84480 bytes
*** [expand] Direct Rendering mp_image_t, 320x176x12bpp YUV planar, 84480 bytes
Muxer frame buffer sending 2 frame(s) to muxer.
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
1 duplicate frame(s)!
2 duplicate frame(s)!
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 430.251 kbit/s (53781 B/s) size: 269176 bytes 5.005 secs 123 frames
Audio stream: 128.000 kbit/s (16000 B/s) size: 80256 bytes 5.016 secs
uninit video: realvid
Encoding completed on Thu Jan 5 23:28:28 CST 2006
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
