I'm wondering if there is a way to get the vcd to be viewd the normal way and not have the sides and tops cut off? ><
Is there a certai screen size that I need to set?
I'm using Tmpenc to do this and the Nero 5.5 burning software to write the vcd. Please help me ;_;
I think your TMPEGNC settings are wrong. Look in the advanced settings tab.
I know my settings are wrong, that is why I'm asking for help ><
I want to know what settings I need to set up to fit on my screen.
When I left my settings on the default settings of Tmpgenc I get a video format with the sides and some of the bottom cut off ><
If I put the center custom size, would that fix the prob?
I'm trying not to be a pain, but I'm quite new to this ;_; -
I was at work when I wrote that one. Now that I'm at home:
In TMPEGnc
Configure -> Advanced
Source Aspct Ratio: 4:3 535 line (NTSC)
Image Positioning Method: Fit to frame
Give this a try and let me know. If you do not live in a NTSC country (where do you live?) then try 4:3 625 line (PAL) instead. I live in the US.
creat dvd to fit your tv screen
By projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 08:37 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 22:49 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18 -
DVD fit on screen
By NHLroyrocks in forum Authoring (DVD)Replies: 6Last Post: 21st Jun 2007, 16:54
