hi there..
could any body tell me about a software that can convert any audio file to 5.1 but I want it to give a true surround and not just to copy the file to other channels (I mean I want the guitar voice to get out from the rears only...and the singer from the center for example)..
I've tried the maven3d pro but it didn't give a true surround (it just copied the same audio into the other channels)
so can any body help me please...
AND THANKS IN ADVANCE....
CAESAR...
Short answer: There is no such thing.
Long answer: Hollywood and Music studios do surround by having MANY multiple source tracks, which they --to use your term--"Copy" or Mixdown to the 5.1 tracks, as well as mixing down to 2 tracks.
When they want to take something that was originally 1 or 2 tracks and make a 5.1 version, they have to painstakingling try at manually separating the various voices/parts into intermediate versions of those aforementioned multiple tracks. This is NOT a surefire possibility, even for those with $$$$$$. Otherwise, it's the application of compression/EQ and the addition of 5.1 ambience that might give the impression of 5.1.
In that way, any good multitrack audio editor can be used, preferrably one that fully supports mixing in 5.1 surround. Maven3D does do this. So does ProTools and Vegas, and some others. But, once again, GOOD LUCK!
Scott -
Not gonna happen. You can't create spatial separation data out of nothing (well, you probably can with the right tools, but it's not worth the trouble. So nobody bothered to develope the right tools.)Originally Posted by caesarhawy
I'm sure it's a fun project, but does it really produce better results than the built-in Pro-Logic II decoding? If it doesn't then I just don't see why you wouldn't rather use the feature you paid for than spend hours trying to get to that point. If it does then i'll shut up back out slowly
My personal opinion
WMV I'll do 5.1 etc...
On DVD I downmix to or use stereo every time... :P Almost everyone in the family uses the bundled players on their PC & come screaming when they have 5.1 issues.
Doing stereo is easier then throwing things!
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 03:42 -
I Give Up. Can't Burn AVCHD DVD Without Audio Being 4-5 Secs Ahead of Video
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 21st Oct 2010, 09:32 -
Audio Filtering Program
By dawson54 in forum AudioReplies: 6Last Post: 13th May 2008, 09:10 -
Program switches audio track priority of dual-audio assets
By PBear in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 16th Nov 2007, 20:36 -
program to increase audio
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2007, 11:36
