    Jan 2006
    Canada
    Okay my video will be approx. 3 hours and 15 minutes.
    I've decided this can be split up between 2 discs. At what point in those 3 hours and 15 mins would you split it? I'm having trouble deciding.
  2. Member Snakebyte1's Avatar
    Mar 2002
    Ontario, Canada
    I would split it at about the 1hr 45min mark, give or take a few minutes based on the content of the scene at that time (ie. at a scene transition).
    Jan 2006
    Canada
    Alright I'll look into that. And yeah, I'll make sure there is some sort of transition scene. The video took short clips from one tape, then a full tape and an almost full tape.
    Total video = 195 mins (approx.)
    1h 45m split = 105 mins
    Remaining = 90 mins
    Which would fit on one DVD cause they are 120 mins each. Just thinking out loud here. I'll try that unless someone else has a better idea.
  4. Member Snakebyte1's Avatar
    Mar 2002
    Ontario, Canada
    The reason I gave that point to split is that if a burnt DVD is going to have problems playing on a DVD player, it often does so near the end of the DVD (ie the outer edge). So I try to avoid burning right to the evey edge of the disc.
    Since you are planning on using 2 discs anyway, I would ensure that you not fill the first disk completely, so a 50/50 split or there abouts would be what I would do...
