Hi Guys,
Does anyone know the region-free hack for the Tevion TSDVD1300?
Thanks in advance,
CJ
The Tevion TSDVD 1300 Player is multi-regional from brand-new from when you take it out of the box after buying it from Aldi and the machine doesn't require a region-hack or code to make this DVD player multi-regional. Hope this information helps? I have a Tevion TSDVD1300 DVD player myself and I've tested out some Region 1 DVDs and they play perfectly, also there is a button on the remote control to adjust the TV system marked as "P/N" meaning PAL/NTSC depending on what colour system your TV set supports, be it PAL only or PAL & NTSC
What kind of idiot replies, re-opens, grave-robs a 5 year old post?
Stoopid newbie question - Tevion DD1018 Hack
By bpuppygrrl in forum Newbie / General discussionsReplies: 11Last Post: 13th Apr 2009, 20:41 -
Region hack required for Tevion DVD3602UKT player
By mfraser in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Sep 2008, 12:07 -
Region Hack needed - Tevion TDVD08
By PocketRocket in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 18:39 -
Region Hack - Tevion TDVD08
By Giosomm in forum DVD & Blu-ray PlayersReplies: 9Last Post: 29th Aug 2007, 08:32 -
Hack needed for Tevion TEV007 (Australia)
By jerseybean in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Jul 2007, 19:36
