hi
keep getting sync issues after goin through svcd 2dvd 1.51.
this has happened a few times now,
exactly at start of cd2 audio goes out by a couple of seconds and i know the release is good cos other people processed it fine.
why is cd1 perfect and the first second onwards of cd2 totally out?
please help
jnsmurf
ps here is the log if it helps
Starting SVCD2DVD: v1.51.2.0
Begin time: 05:32:02
******** Ripping BIN images to get mpegs (VCDGear -fix)
VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> F:\just like heaven unrasred\pdy_jlhtc_svcda.bin
.mpg dest(Out) -> F:\just like heaven unrasred\pdy_jlhtc_svcda.mpg
Fix MPEG Errors
[pdy_jlhtc_svcda.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 832686876 bytes [06:48:19]
#searching...
1 track(s).
Setting read size to: 2352
Setting write size to: 2324
# Track 1 -> writing...
# 0%
# 0 MPEG block correction(s) applied
# 0 Blocks padded
# OK!
Language: English
.bin src(In) -> F:\just like heaven unrasred\pdy_jlhtc_svcdb.bin
.mpg dest(Out) -> F:\just like heaven unrasred\pdy_jlhtc_svcdb.mpg
Fix MPEG Errors
[pdy_jlhtc_svcdb.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 809602584 bytes [04:35:61]
#searching...
1 track(s).
# 0%
# 0 Blocks padded
# OK!
(Total size: 1587MB, Duration: 00:03:40, Rate(MB/Min): 431.76)
Analysing File: F:\just like heaven unrasred\pdy_jlhtc_svcda.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Analysing File: F:\just like heaven unrasred\pdy_jlhtc_svcdb.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:06.1f]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0f.12]
-->Processing 2 mpeg files
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 794MB, Duration: 00:01:50, Rate(MB/Min): 430.32)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 72MB, Duration: 00:01:28, Rate(MB/Min): 48.66)
******** Trimming start of video ES
- Nothing to do.
******** Multipexing elementry streams
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [???] File F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpv)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 480
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 2450000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpa)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 1 original
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 2720800
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
INFO: [???] STREAM e0 completed @ frame 67555.
INFO: [???] STREAM c0 completed @ frame 112563.
INFO: [???] Multiplex completion at SCR=243146459.
INFO: [???] Video e0: buf= 27982 frame=067555 sector=00371355
INFO: [???] Audio c0: buf= 2080 frame=112563 sector=00037448
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 746993837 bytes
INFO: [???] Sequence headers: 4782
INFO: [???] Sequence ends : 0
INFO: [???] No. Pictures : 67556
INFO: [???] No. Groups : 4782
INFO: [???] No. I Frames : 4782 avg. size 39266 bytes
INFO: [???] No. P Frames : 20477 avg. size 14861 bytes
INFO: [???] No. B Frames : 42298 avg. size 6026 bytes
INFO: [???] Average bit-rate : 2211200 bits/sec
INFO: [???] Peak bit-rate : 2310800 bits/sec
INFO: [???] BUFFERING min 15 Buf max 185470
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 75643012 bytes.
INFO: [???] Syncwords : 112565
INFO: [???] Frames : 112565 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] BUFFERING min 15 Buf max 683
INFO: [???] MUX STATUS: no under-runs detected.
(Total size: 807MB, Duration: 00:01:45, Rate(MB/Min): 458.51)
Analysing File: F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 771MB, Duration: 00:01:41, Rate(MB/Min): 456.50)
(Total size: 73MB, Duration: 00:01:23, Rate(MB/Min): 52.31)
- Trimmed 1643 bytes.
INFO: [???] File F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpv)
INFO: [???] Scanning for header info: Audio stream c0 (F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpa)
INFO: [???] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [???] rough-guess multiplexed stream data rate : 2621000
INFO: [???] STREAM e0 completed @ frame 68582.
INFO: [???] STREAM c0 completed @ frame 114294.
INFO: [???] Multiplex completion at SCR=246883913.
INFO: [???] Video e0: buf= 220360 frame=068582 sector=00359561
INFO: [???] Audio c0: buf= 1408 frame=114294 sector=00021728
INFO: [???] Video Stream length: 722989454 bytes
INFO: [???] Sequence headers: 4859
INFO: [???] No. Pictures : 68583
INFO: [???] No. Groups : 4859
INFO: [???] No. I Frames : 4859 avg. size 39363 bytes
INFO: [???] No. P Frames : 21999 avg. size 13323 bytes
INFO: [???] No. B Frames : 41726 avg. size 5718 bytes
INFO: [???] Average bit-rate : 2108000 bits/sec
INFO: [???] Peak bit-rate : 2325600 bits/sec
INFO: [???] BUFFERING min 15 Buf max 181059
INFO: [???] Audio stream length 43889284 bytes.
INFO: [???] Syncwords : 114296
INFO: [???] Frames : 114296 padded
INFO: [???] BUFFERING min 15 Buf max 395
(Total size: 754MB, Duration: 00:02:12, Rate(MB/Min): 342.57)
Analysing File: F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\BadgerSoft\SVCD2DVD\dummymenuPAL.mpg...
STAT: Processing F:\just like heaven unrasred\pdy_jlhtc_svcda_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
STAT: Processing F:\just like heaven unrasred\pdy_jlhtc_svcdb_DVD.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
!!!: Forced to truncate audio channel 1 gap from 88560 to 23819
-->: DVDFolders creating table of contents
scanning F:\just like heaven rdy\VIDEO_TS/VTS_01_0.IFO
-->: Creating menu for TOC
STAT: Processing C:\Documents and Settings\jason\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.1710.16171\a1b360d7-0216-44f0-b898-8e0b200423fe\menu.mpg...
(Total size: 1561MB, Duration: 00:04:09, Rate(MB/Min): 375.20)
============ Complete ============
============ Duration: 00:19:24
Use version 2. It maintains sync better.
mkv audio sync issues
By Bloodnut05 in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2011, 05:06 -
Audio Sync Issues!!!!
By earthXDust in forum EditingReplies: 3Last Post: 30th May 2011, 00:23 -
audio sync issues.................
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 17:48 -
Audio sync issues
By andy99 in forum EditingReplies: 7Last Post: 16th Sep 2008, 23:47 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 09:38
