I'm trying to export my timeline from premiere pro and I am getting an error message that states an internal error occured and premiere will attempt to save my project but needs to shut down. No other details as to what happened. I tried to export with Debugmode Frameserver and then as .avi with the same results. I exported the timeline just before as .wav with no problems. I know this will fun one to answer, but, any suggestions?
More info needed.
What is your project setting?
Can you preview the project after rendering the full timeline?
Can you save the project before exporting?
How are you exporting?
Will export to MPeg2 work? Or quick DVD?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'd suggest doing a quick test with another video on the timeline, something using a different codec. Or perhaps reinstalling, making sure the codec used for the clip on your timeline was working correctly. If you have more then one codec installed for that type of video, particularly if one duplicates something that comes with prem (mainconcept?), might want to try temporarily disabling the other codec.
But all just guesses, maybe someplace to look, or post more info for prem experts. -
Okay,
Export setting are as follows
Microsoft DV AVI
NTSC
D1/DV NTSC (0.9) pixal apect ratio
Audio
Uncompressed
48kHZ
16bit
stero
I have 4 video tracks and 3 audio tracks, all tracks are locked so nothing got moved out of position accidently, export setting to "Work Area Bar" and the bar is set over all the video.
edDV
Yes I can preview the timeline in the preview window after a full render of the timeline and I can save the project.
mikiem
I will try a shorter video that I will make now and post results.
Thanks -
Well it seems that you can not have the video or audio lines locked when trying to export. I ran a small 5 min video test and it worked with .avi and frameserving. So I went to the original project and ran it with unlocked timelines and a short section and it worked. I am in the process of frameserving the whole project. Sometimes when we post, with the direction and suggestions of others, we figure out out own STUPID mistakes. Thanks
Exporting from Adobe Premiere Pro not working
By Devilsadvocate in forum EditingReplies: 1Last Post: 29th Mar 2012, 11:04 -
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Mar 2011, 14:41 -
Premiere Pro Cs4 exporting issues
By gooberguy in forum EditingReplies: 8Last Post: 27th Jan 2011, 21:15 -
Render before Exporting in Premiere Pro
By newsphotog in forum EditingReplies: 1Last Post: 29th Sep 2009, 10:39 -
Exporting movie from Premiere Pro 2
By daninor in forum Video ConversionReplies: 16Last Post: 18th Apr 2009, 16:54
