Hey guyz...
is there a program that can convert avi to mkv? and make the file size smaller then an avi file??
i say DB doing it for bleach... any ideaS?
Results 1 to 17 of 17
avi and mkv are container formats not any video formats like divx,xvid, avc/h264.
convert the video to a smaller size with a encoder like virtualdub. you can use divx,xvid,avc/h264 etc.
use MKVtoolnix to create a mkv file. -
and mkvtoolnix = mkvmerge = mmg ....my automatic tool link wont work if you use /...
hmm i don't quite understand what you are talking about..
DB uses AVC what is avc? so if i convert straight from avi to mkv is that possible? -
Dattebayo uses H.264 for his mkv encodes, at least according to bleachportal. H.264 = AVC. Like I said though, mkv generally uses less overhead so if you remux to mkv from avi it should be smaller. But not 75MB vs. 175MB. That requires re-encoding.
So basically I think you want to encode to AVC more so than using mkv. I really wouldn't recommend AVC in avi though. mp4 would be fine if the audio is aac or mp3. -
Muxing is just like linking the two files together with no modification to either file.
(That's the short explanation) -
hmm i used that program to mux the file... in the end... its the same size... how can i compress it further? can i use something that compresses it straight like real media producer?
hm... it looks most of peoples using MKV as the video file format.....
but the baldrick tips it a bit tough. is it an easy way or software that can convert the mkv to avi or avi to mkv
or can also burn mkv file to vcd without converting to avi or mpeg file first??? -
For VCD, you have to convert to MPEG-1. It is possible for an mkv to contain VCD compliant MPEG-1 though, in which case you could remux.
avi to mkv is easy. Just use mmg/mkvmerge. mkv to avi is harder since mkv is the more powerfull of the two formats. If the mkv uses features that avi doesn't support then you have problems. -
when i am using that software.....
what format and all should I save it ??
as in what are the settings that I must set?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Converting MKV to AVI (720p)
By shorto in forum Video ConversionReplies: 9Last Post: 24th Mar 2011, 05:41 -
Converting .mkv to .avi using AVIMuxGUI
By raphytaffy in forum Video ConversionReplies: 3Last Post: 16th Jun 2010, 21:46 -
By davidw89 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 10:38 -
In need of help with converting .mkv to .avi format
By nabeelnk1 in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 15:47
