Closed Thread
    Jan 2003
    Sheffield
    I am having major difficulties with fraps and after 14 days of fiddling with it I am giving up. Are there any good video capturing progs about? I want them to be compatible with divxtodvd or avi2dvd if possible.
    Cheers,
    K
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi BPH2002,
    What are you trying to capture with fraps?
    What problems are you having?
    Before giving up, provide details and someone may be able to help and / or suggest a better application.
    Any snow up north?
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Jan 2003
    Sheffield
    A bit of snow, not much heh heh
    Basically my problem involves video capturing a file as I play it using VLC. Then I want to use a dvd conversion prog to burn it onto dvd, for use on conventional players.
    Original topic : https://forum.videohelp.com/viewtopic.php?t=288081
    I am fairly sure this is the only way of doing this.
    Thanks for replying and your help,
    Katie
    one topic is enough.
    reply to add more information.
