I have installed both of the following (not at the same time of course) in an attempt to get subtitles working with Windows Media Player 10 on Windows XP Pro SP2.
VobSub_2.23.exe
vsfilter.2.37_nt.exe
With the first install the AVI file plays and subtitles work but the picture is extremely grainy (all you can see is basic shapes, very little detail). Also 95% of the picture is green with a bit of blue and cyan. With the second there is no picture. The green arrow shows up in the system tray in both cases.
Without either installed the avi file plays ok but of course there are no subtitles.
I am using the very latest version of DivX. This is a DivX AVI file.
The same thing happens with all five of the current AVI files that I have on my computer. All are DivX and have the .sub and .idx files.
If I play a DivX file without subtitles then the picture is fine. Same goes if I delete the sub/idx files.
problem with VobSub
By nazim in forum SubtitleReplies: 4Last Post: 23rd Jun 2011, 15:32 -
Problem with vobsub 2.23
By mop59136 in forum SubtitleReplies: 2Last Post: 8th Mar 2011, 11:07 -
Problem with Vobsub in Windows Vista 64 bits
By Talayero in forum SubtitleReplies: 7Last Post: 30th Aug 2008, 10:23 -
vobsub install problem
By bmwracer in forum SubtitleReplies: 6Last Post: 3rd Aug 2008, 17:08 -
VobSub/VirtualDub Install Problem
By locoblacbelt in forum SubtitleReplies: 0Last Post: 18th Jul 2008, 11:35
