I got the samsung dvd-r100 for christmas. Recorded some of my travel video tapes onto a DVD-R disc. When I finalize the disc and play on another DVD player (Sharp and LG), the disc plays until a certain chapter and freeze (the freezing on chapters is random for different videos (ie. some videos stop at the 5th chapter, others 7th or 8th). If I try to skip the chapter, it will play a few seconds of the next chapter and then repeats itself. This problem seems to be the auto chaptering problem when u use a DVD-R (in V mode).
When I use a DVD-RW disc (formatted in VR mode), I do not have any problem playing back on other players (because there is no auto chaptering). For the Samsung DVD-R100 there is no way that I can turn on the auto chaptering.
But when I record from TV and when I finalize the DVD-R, I do not face the problem. The disc can be played on other DVD players. What is the problem???
Is there anyone with the same problem.
If you have a solution, please helpThank you.
Called samsung technical support in Singapore, but they are just as blur.
Results 1 to 1 of 1
Getting the Best Frame Rate - Canon Vixia HF R100
By PeripheralVisionaryX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 20th Jun 2011, 17:15 -
Problem with Samsung DVD-R155
By eatonsboy in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2010, 13:01 -
Problem with Samsung DVD-P181 ! Pls help !
By lucianserpescu in forum SubtitleReplies: 1Last Post: 21st Mar 2009, 12:19 -
Using Samsung DVD-recorder through hi-fi – problem
By kwil in forum Newbie / General discussionsReplies: 0Last Post: 26th Nov 2008, 12:24 -
Unlock code for my Samsung DVD-R100
By missthib in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Jul 2008, 06:22
Thank you.
