Hi Guys.
I am trying to encode my DV video into Xvid. You will probably say dont do this, etc etc but this is how I want to do it and I think it gives really good quality because I don't want to split the avi to fit multiple dvd r's.
Anyway I'm encoding with VirtualDub and about 13 minutes or so, The computer will freeze. I tried a couple of time with no luck
What's going on ?
Results 1 to 9 of 9
It just freezes ? No error messages ? Just Lock up ?
Firs thought (given so little to go on) over heating or memory problems.
Over-heating is easy to diagnose. Take the covers off your PC (or open the top if it's a desktop PC) and point a standard desk fan into the guts of the machine. Turn it on and let it blow through while you try your next encode. If everything works, heat was your problem and all you need to do is get some decent cooling into your machine.
If it still locks up, it's onto the next idea.Read my blog here.
If XVID freezes, try Microsoft MPEG4 V3 codec (should be already on the PC if you have WMP9 or 10). It should offer compression similar to that of XVID (albeit slightly more bloated).
It may also help if you get the latest XVID binaries. I believe one was released just around Christmas -
Thanks Guys I will see what happens. I know I have been having some pc problems so it is most likely that I think. PC Is due for a format
XviD is one of the best stress testers out there. Also, like all things PC components ware out. So even if your RAM was good, it doesn't mean that it is now.
You could try some other stress/RAM testers.
Reformating won't fix hardware problems. If that is what it is. -
Ok I got the new Xvid.
Here is the error log it gave me. Can someone please help.
VirtualDub crash report -- build 2540 (release)
Disassembly:
031e42e0: 89aaf4000000 mov [edx+f4], ebp
031e42e6: 53 push ebx
031e42e7: ff15043d2c03 call dword ptr [032c3d04]
031e42ed: 8d9380000000 lea edx, [ebx+80]
031e42f3: 89542450 mov [esp+50], edx
031e42f7: 52 push edx
031e42f8: ff15043d2c03 call dword ptr [032c3d04]
031e42fe: 8d9300010000 lea edx, [ebx+100]
031e4304: 89542458 mov [esp+58], edx
031e4308: 52 push edx
031e4309: ff15043d2c03 call dword ptr [032c3d04]
031e430f: 8d9380010000 lea edx, [ebx+180]
031e4315: 89542460 mov [esp+60], edx
031e4319: 52 push edx
031e431a: ff15043d2c03 call dword ptr [032c3d04]
031e4320: 8d9300020000 lea edx, [ebx+200]
031e4326: 89542468 mov [esp+68], edx
031e432a: 52 push edx
031e432b: ff15043d2c03 call dword ptr [032c3d04]
031e4331: 8d9380020000 lea edx, [ebx+280]
031e4337: 89542470 mov [esp+70], edx
031e433b: 52 push edx
031e433c: ff15043d2c03 call dword ptr [032c3d04]
031e4342: 83c418 add esp, 18
031e4345: 8b6c2460 mov ebp, [esp+60]
031e4349: 8b550c mov edx, [ebp+0c]
031e434c: b903000000 mov ecx, 00000003
031e4351: f6c220 test dl, 20
031e4354: 7405 jz 031e435b
031e4356: b906000000 mov ecx, 00000006
031e435b: 8bb424b4000000 mov esi, [esp+b4]
031e4362: 8b6f6c mov ebp, [edi+6c] <-- FAULT
031e4365: 894c2448 mov [esp+48], ecx
031e4369: 33d2 xor edx, edx
031e436b: 83e501 and ebp, 01
031e436e: 89542468 mov [esp+68], edx
031e4372: 8b15f43c2c03 mov edx, [032c3cf4]
031e4378: 89542470 mov [esp+70], edx
031e437c: 8b15f03c2c03 mov edx, [032c3cf0]
031e4382: 89542474 mov [esp+74], edx
031e4386: 897c2444 mov [esp+44], edi
031e438a: 33d2 xor edx, edx
031e438c: 83f501 xor ebp, 01
031e438f: 0f94c2 setz dl
031e4392: 33c0 xor eax, eax
031e4394: 89542420 mov [esp+20], edx
031e4398: 8beb mov ebp, ebx
031e439a: ba05000000 mov edx, 00000005
031e439f: 8954241c mov [esp+1c], edx
031e43a3: 8bd8 mov ebx, eax
031e43a5: 8b7c2444 mov edi, [esp+44]
031e43a9: ff7778 push dword ptr [edi+78]
031e43ac: 8b4c2468 mov ecx, [esp+68]
031e43b0: ffb1f0000000 push dword ptr [ecx+f0]
031e43b6: 55 push ebp
031e43b7: 56 push esi
031e43b8: 8b4c2430 mov ecx, [esp+30]
031e43bc: ff948c80000000 call dword ptr [esp+ecx*4+80]
031e43c3: 83c410 add esp, 10
031e43c6: 85c0 test eax, eax
031e43c8: 7463 jz 031e442d
031e43ca: 8b4c2464 mov ecx, [esp+64]
031e43ce: 8bb9f0000000 mov edi, [ecx+f0]
031e43d4: 897c2440 mov [esp+40], edi
031e43d8: 83ff02 cmp edi, 02
031e43db: 7e50 jle 031e442d
031e43dd: 8b4c24 mov ecx, [esp+24]
Windows 5.1 (Windows XP build 2600) [Service Pack 2]
EAX = 01611f40
EBX = 04c2d400
ECX = 00000003
EDX = 00000082
EBP = 03e76900
DS:ESI = 0023:04c2d080
ES:EDI = 0023:00000000
SS:ESP = 0023:04c2cf88
CS:EIP = 001b:031e4362
FS = 003b
GS = 0000
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffaaaa
MM0 = ffffffff00000001
MM1 = 0000ffff0000ffff
MM2 = ffffffff0000ffff
MM3 = 00000000ffffffff
MM4 = 008000800080007f
MM5 = 0080008000800080
MM6 = 0080008000800080
MM7 = 0000000000000000
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'xvidcore'...
...while compressing frame 31961 from 02dc5000 to 02f10020 (VideoSequenceCompressor.cpp:406)...
...while running thread "Processing" (thread.cpp:120).
Thread traces:
Thread 00000870 (Main thread)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(126)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(124)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(409)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(429)
Thread 00000a38 (FastWriteStream)
Thread 000007a8 (Processing)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(530)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\FilterSystem.cpp(517)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSequenceCompressor.cpp(403)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSequenceCompressor.cpp(420)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Dub.cpp(2777)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Dub.cpp(2817)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Dub.cpp(2609)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSource.cpp(1623)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\VideoSource.cpp(1658)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\sour ce\Dub.cpp(2614)
Thread 00000908 (Dub-I/O)
Thread call stack:031e4362: xvidcore!xvid_encore [031a0000+26d84+1d5de]
031e1fb4: xvidcore!xvid_encore [031a0000+26d84+1b230]
031e1fe3: xvidcore!xvid_encore [031a0000+26d84+1b25f]
031c93b9: xvidcore!xvid_encore [031a0000+26d84+2635]
031c8e60: xvidcore!xvid_encore [031a0000+26d84+20dc]
7c90e3ed: ntdll!NtRequestWaitReplyPort [7c900000+e3e1+c]
7c9132f8: ntdll!CsrClientCallServer [7c900000+132a1+57]
7c81079e: kernel32!CreateRemoteThread [7c800000+10626+178]
7c8107e1: kernel32!CreateRemoteThread [7c800000+10626+1bb]
7c8107fd: kernel32!CreateRemoteThread [7c800000+10626+1d7]
7c9105c8: ntdll!RtlFreeHeap [7c900000+1043d+18b]
7c910551: ntdll!RtlFreeHeap [7c900000+1043d+114]
7c91056d: ntdll!RtlFreeHeap [7c900000+1043d+130]
7c80262a: kernel32!WaitForSingleObjectEx [7c800000+2550+da]
77c2c2de: msvcrt!free [77c10000+1c21b+c3]
77c2c2e3: msvcrt!free [77c10000+1c21b+c8]
7c802600: kernel32!WaitForSingleObjectEx [7c800000+2550+b0]
02036c7e: mcdvd_32!DSCompressBuffer_DV [02030000+37aa+34d4]
77d4a044: USER32!ClientThreadSetup [77d40000+a00a+3a]
77d494be: USER32!GetWindowLongA [77d40000+945d+61]
77d4b903: USER32!SendMessageW [77d40000+b8ba+49]
77d56623: USER32!IsDlgButtonChecked [77d40000+165fc+27]
015d8582: xvidvfw!DriverProc [015d0000+6d20+1862]
031c6dcd: xvidcore!xvid_encore [031a0000+26d84+49]
015d703d: xvidvfw!DriverProc [015d0000+6d20+31d]
7c910833: ntdll!RtlAllocateHeap [7c900000+105d4+25f]
7c80b5b8: kernel32!GetModuleHandleA [7c800000+b529+8f]
7c80b58c: kernel32!GetModuleHandleA [7c800000+b529+63]
7c80b5a1: kernel32!GetModuleHandleA [7c800000+b529+78]
00cc1605: MsgPlusLoader1!MessengerPlusGlobalHook [00cc0000+1480+185]
7c910732: ntdll!RtlAllocateHeap [7c900000+105d4+15e]
7c9106ab: ntdll!RtlAllocateHeap [7c900000+105d4+d7]
7c9106eb: ntdll!RtlAllocateHeap [7c900000+105d4+117]
7c911538: ntdll!wcsncpy [7c900000+10a8f+aa9]
7c911bff: ntdll!RtlInitializeCriticalSection [7c900000+11b2d+d2]
77c2c3ce: msvcrt!free [77c10000+1c21b+1b3]
77c2c42e: msvcrt!malloc [77c10000+1c407+27]
02065e35: mcdvd_32!DSCompressBuffer_DV [02030000+37aa+3268b]
02036fcf: mcdvd_32!DSCompressBuffer_DV [02030000+37aa+3825]
0203220f: mcdvd_32!0000220f
0043a0d9: ResampleInfo::computeBounds()
0043beca: Resampler::_DoRow()
0043ca14: Resampler::Process()
75a718a8: MSVFW32!ICSendMessage [75a70000+187d+2b]
75a74c09: MSVFW32!ICCompress [75a70000+4ba6+63]
0049de0c: VideoSequenceCompressor:
ackFrame()
0046ea46: Dubber::WriteVideoFrame()
0046f12f: Dubber::ThreadRun()
7c90da54: ntdll!NtFreeVirtualMemory [7c900000+da48+c]
7c918331: ntdll!RtlReAllocateHeap [7c900000+179fd+934]
7c918632: ntdll!RtlReAllocateHeap [7c900000+179fd+c35]
7c9183fe: ntdll!RtlReAllocateHeap [7c900000+179fd+a01]
7c81eb33: kernel32!RaiseException [7c800000+1eae1+52]
7c90d919: ntdll!NtDuplicateObject [7c900000+d90d+c]
7c80e07b: kernel32!DuplicateHandle [7c800000+e016+65]
0052939f: VDThread::StaticThreadStart()
0056b99c: _threadstartex@4()
7c80b50b: kernel32!GetModuleFileNameA [7c800000+b357+1b4]
-- End of report -
Every XviD crashing post I have seen starts off like that. 99.9% sure it isn't the hardware. Always turns out to be the hardware though.
Still there is a possibility that it isn't hardware releated. I'd still suggest that you test your RAM. -
Well I Guess I'll have to see what happens next week, I just brought a new 250 Gig hard drive to backup my stuff. Formatting next week then will try converting again.
XviD 1.3.0 Included Converters
By thezanny in forum Video ConversionReplies: 1Last Post: 12th Mar 2011, 10:19 -
Convert X to DVD - preview blank (log included)
By seedybrick in forum Video ConversionReplies: 8Last Post: 3rd Jan 2008, 08:28 -
problems converting video with 3GP (error log included)
By Luke Vader in forum DVD RippingReplies: 0Last Post: 17th Dec 2007, 16:20 -
DVDAuthorGUI Unknown error - log included *SOLVED*
By ChibiTomo in forum Authoring (DVD)Replies: 2Last Post: 9th Oct 2007, 13:18
