I am new at video editing. What external harddrive size do I really need?
I will probably be shooting 2 party's a month with my mini dv camcorder in the summer?
Figure 13GB/Hr of DV. Double that for editing times the amount of video you want to keep on the hard drive.
Or to make it simpler, go for a 160 to 300GB hard drive and you can't go wrong.
You can't add another internal drive? That's much simpler.
If you go external, I would look into a external SATA box and drive. You will need a SATA card, though, with a external hookup.
Here's some to look at: http://www.cwol.com/serial-ata/sata-drive-enclosures.htm
Or you can go with a Firewire card and external box and drive. I wouldn't recommend USB, Firewire has less problems. -
Cool, For now I am just going to buy a EXTERNAL USB 2.0+FIREWIRE HARD DRIVE+ MAXTOR 250GB 16MB METAL GEAR.
Time to work -
That should work well for you. It's nice to have both Firewire and USB. I use Firewire almost exclusively for my laptop and I have no problems. USB is handy for connecting to other computers occasionally.
maybe cheaper to buy a 250GB internal hdd and put it into an external enclosure. saved me about $100
What We Do In Life, Echoes In Eternity....
Trying to create files to plug External Harddrive into TV
By mugsie in forum Video ConversionReplies: 6Last Post: 5th Jul 2011, 10:46 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 12:20 -
External harddrive repeatedly asks me to format
By orfajackson in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2009, 15:15 -
Suggestion on external harddrive
By jyeh74 in forum ComputerReplies: 17Last Post: 13th May 2009, 02:40 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 17:33
