been trying now for days ,im going nutty ,need help fast
im using every proggy available ,and still get the same converts a minute or less the stops ,ffmpeg.exe has encounted a problem.dl ed every codec u can think of ,tried everyway i know,i donated to svcd2dvd £10 and cant even get it to work plz someone advise me![]()
Results 1 to 13 of 13
You haven't told us much, if anything, as Baldrick have pointed out.
What codec does AVI use? Use GSpot / AVICodec / VideoInspector to determine that.
Then, what are you trying to convert TO? What's the eventual destination?
Didn't give us much to work with, did you? -
ive tried using,svcd2dvd ,which comes up with ffmpeg error ,also ive tried winavi,which starts off ok and does about 1-2% and says find a nav file mismatched,dvd creator maybe cannot run length =1,item =0
also divx 2dvd vso which again starts off ok does about 15 seconds converting then freezes ,and a few more all same results
ive setup loads of codecs and loads of proggys on my pc ,could that have anything to do with it .i thought of formating and just putting 2 converters on winavi and svcd2dvd wat u think thx
all i want is a dvd i can play on my standalone dvd player
either ts or vob files ,iso anything that will work -
Again, what is it you're trying to convert to DVD? No problem is ever solved by running in every direction imaginable at once. "loads of codecs" and "loads of proggys" is a good start to failure...
/Mats -
im a newbie to doing avis divx and stuff ,and would very much appreciate some help
im trying to convert a divx video dl ed from the internet to play on my standalone dvd player -
And the error is?
Does it say MORE than that?,also ive tried winavi,which starts off ok and does about 1-2% and says find a nav file mismatched
Maybe cannot run? What the heck is that?,dvd creator maybe cannot run length =1,item =0
Freezes... How long did you wait? Conversion usually takes hours.also divx 2dvd vso which again starts off ok does about 15 seconds converting then freezes ,and a few more all same results
A shotgun approach is more likely to mess up your PC than to produce a solution.ive setup loads of codecs and loads of proggys on my pc ,could that have anything to do with it
I would suggest you make sure all your videos are PLAYABLE with no errors first. Tell us WHAT format they're in, what codec, and what do you have to work with, and what is your eventual target. THEN we'll probably be able to suggest something..i thought of formating and just putting 2 converters on winavi and svcd2dvd wat u think thx
So far the only sense we got was "OMG! I've tried f***ing Everything! NOTHING works! WTF!?" -
OK, several people have suggested things to do to help you out. So instead of posting that long Nero logfle in here, why not try listening to them?
First you need to tell us information about your problem file, such as which
codec it needs, is it PAL or NTSC, etc. To DO that you need to install one of the codec identifiers that one of the earlier posters pointed out to you (GSpot, etc), load the file into it, & report back what it shows. If you aren't willing to do that , then please do not bother to complain any more in here.
Also be prepared to uninstall most of the codec packs you say you have, since that is more likely than not the cause of your problem.
From here on out, it is up to you... -
Frankly, all that log says is "I crashed while converting something"
256 MB is a little on the lean side, but it shouldn't cause a crash like this.
/Mats
DV-> AVI conversion
By bodomalo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Dec 2010, 21:06 -
avi conversion
By joecass in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2010, 14:11 -
TP to AVI conversion
By nic3 in forum Video ConversionReplies: 0Last Post: 20th Nov 2009, 17:04 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
mpg to avi conversion
By rwagar in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 22:27
