I just converted a movie to mpeg-2 using tempgenc.I used the video format 640x352,i know this is not a standard video format for dvd.I would like to know how i can make this into a video ts folder for burning as tempgenc dvd author will not let as it is not the right format.I also would like to know what program to use?
Results 1 to 10 of 10
You can't. Why didn't you create a compliant DVD res when you where at it?
You could try patching the mpeg header with DVDPatcher to a valid DVD res to make TDA accept it, but if your DVD player will, is another story.
/Mats -
Nero would probably let you do it, though it will complain first. It sure complained about my SVCD being non-standard (both video and audio)
Even you manage to author such a non-standard resolution, there is no guarantee your player (or any player) will play it correctly, if at all.
Why would you knowingly encode to a non-compliant resolution, then expect to be able to author it ?Read my blog here.
Thanks for your replys.I did it at the resolution i did because it was originally widescreen and i do not like widescreen.If i make it 720x480 it stretches the charactors to much.
Guns1inger how do i do that?I'm somewhat a amateur at this,though i have done a few movies successfully.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
