It seems that the new sony copy protection is starting to create problems,can somone make a suggestion, and I did try dvd decryptor,dvd shrink,clone dvd ,with any dvd,dvd for free,iso buster and nothing seems to work . Lou![]()
Results 1 to 30 of 58
I have not come accross asingle movie I have not been able to rip yet.
AnyDVD 5.7.2.1
Instead of struggling like so many others here seem to do, just get yourself the latest version of this tool. Rin it and DVDsrhink the hell out of it.
Every single movie that creates hug threads I was able to rip the very 1st attempt. The right tool will defeat whatever these A holes come up with.No DVD can withstand the power of DVDShrink along with AnyDVD! -
I agree, I used the new dvdfabdecrypter out today and had no problem backing up mY copy. That and good ol shrink.
There is a BIG highlighted topic by the mods on I can't back up this dvd with dvdshrink, dvddecrypter, etc....
Used DVDFab Decrypter and the cave worked fine---but "the Wedding Crashers" decrypted fine, but Shrink would not work. Kept giving 4 200mb vob files instead of main movie. Tried to rerip movie only, didn't work. Abyone else???
Yep, must be some other reason because i did them both like this,
Wedding Crashers "Uncorked" - "DVDFab Decrypter 2.9.6.5 & DVD Shrink 3.2"
The Cave - "DVDFab Decrypter 2.9.6.5 & DVD Shrink 3.2"
Did not even update to the next version of DVDFab Decrypter yet.
Just finished watching The Cave BU.
Again, NO ANYDVD 8) -
From October? That's about 4 or 5 versions old.Originally Posted by DaywalkerZane
If you want freeware learn a programming language and write your own code. Good reliable software costs money. Software costs compensate those who provide you with the solution to not having to learn coding. Support your programmers and purchase the code you use most. At the very least, send donations to those who provide software as freeware. Nobody should expect freeware to be free. If you use it, at least support those who have helped you by compensating their efforts. -
DVDFab Decrypter IS NOT the same as DVDFABOriginally Posted by DaywalkerZane
DVDFab Decrypter IS FREE!!!!
But either way, WAY OLD version.... definately need to update. -
[?] Are you only doing the movie? or full disc with menus extras?? As I am using the 'Latest - Last' version of "FAB-D" and "Shrink"Originally Posted by Noahtuck
I am able to 'rip' to harddrive, and playback just fine but..
Can not shrink "THE CAVE" shrink reports a file size of over 5gb...
And 'Wedding Crashers' - "The Uncorked Version" once shrinked/burned has real troubles at the points of added info over the 'Theater Version'.....
Tried "IfoEdit" and "VOBBlanker" just opening, processing at the 'factory settings' and saving the files and not doing any personel changes to the files.
DVD Shrink 3.2.0.15 / DVDFab Decripter 2.9.6.6Originally Posted by taboo
Cave reports needs 4939 MB when a shrinked single sided DVD can only be 4464 and shrink will not go below 98.8% on the main movie folder...??
So what are you doing different? Are you using "DL" disc? -
I am for main movies only.
Main movie is 4174 MB and 100% including all audio tracks. So after leaving one I need its even smaller (4164 MB) -
Me and a friend watched my BU of the wedding crashers tonight, full disc, the uncorked version (8 minutes longer ?) and it played perfectly.Originally Posted by DavidEC
The only reason i did a full disc of that one was because there would have been too much monkeying around to do the movie only.
And when i did the cave i did movie only, but when i had it opened in shrink it gave me no problem for the size to do a whole disc BU.
But i will try the whole disc again and burn to see what heppens 8) -
i used dvd 95 copy pro.....and any dvd's newest version and it worked fine, also did wedding crashers.....this week did transporter 2, constant gardener, red eye.....all works fine..........................
$60+ in one week on DVDs? Plus blanks? That's a considerable sum especially considering the money you spent in previous weeks for the other movies.Originally Posted by dlrtyblrdz
where do you get the $60.00 week ?
when blanks are on 500 for 100 bucks
so i dont know where your getting that crazy amount -
So you are admitting to copying RENTAL movies in this forum????
That takes huge balls!No DVD can withstand the power of DVDShrink along with AnyDVD! -
I sense dirtybirdz is going to be leaving us for a bit.
Copying rentals is a violation of the law and can result in jail time and hefty fines. -
if you read what i wrote, i never admitted it, i was just stating what options are out there, think before you accuse...........
i actually do spend a lot of money on dvds buying and backing them up...but if you have a good job, and you watch it, your fine....dont take your penny pinching problems out on me. 8)
in that case, the videos are $22.99, $24.99, $22.99, plus blanks. Even if you didn't steal them, you are advocating Warez which is a violation of the forum rules. If you did steal them think about everyone you are hurting by your theft. If you like the movies that much support your actors, production people, and those who create the packaging and contents by purchasing the meida.
Don't recommend theft on a site dedicated to video. -
fair enough, i shouldnt of said that option, my fault, but like i said, i do spend a lot of money to support them and back them up.
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
Bloody Hell! Look at the copy protection for "Reservation Road"
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2008, 19:04 -
How many of you have "downgraded" from Vista back to XP?
By bobogs in forum ComputerReplies: 58Last Post: 31st Aug 2007, 23:37 -
Does DivXToDVD's "back-up" function copy or re-encode or both?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2007, 18:00 -
Why to make "back-up's" of DVD's or TV programs?
By JimboS in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2007, 06:39
