Just bought the CH-DVD 300 and was plesantly surprised to find that it will shuffle play MP3 discs, even MP3 DVD discs, although there is no mention of it in the operation guide or their website.
Also found that it will display ID3 tag info. The problem is that it displays the ID3 tag info very erratically. In fact, most of the time, it only displays the file name. Is there some way to set the mode where it always displays the ID3 tag info properly? Any help would be appreciated. Thanks in advance.
wwaag
Could it be something with ID3v1 and ID3v2 tags?
/Mats -
Thanks for the reply. Problem solved. You're right, it only likes 3v1 tags. Most of my selections were 3v2. Transferred 3v2 info to 3v1, reburned, and now it works great.
This is really a neat little player for the size and price.
wwaag
Any free ID3 or music tag editor/tool that can convert character set.
By csh in forum AudioReplies: 1Last Post: 17th Jun 2012, 12:09 -
Changing the name tag of a DVD audio track
By DeathStalker77 in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2012, 12:01 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 09:28 -
Possible ID3 Tag Problem
By Graham099 in forum Authoring (DVD)Replies: 0Last Post: 11th Jul 2007, 07:45
