Can someone give me a short pros and cons of using each of the above programs? What are strengths and weakness of each? Thanks for any replies
I haven't used cloneDVD, but as for the others
DVD Shrink 3.2
+ Free
+ Faster than re-encoding
+ Good quality down to a certain level of compression (level varies)
+ AEC/Deep analysis
+ Can rip older disks
+ integrates with several burning apps for one click processing
+ Reauthor mode for changing structures
- transcodes, does not re-encode
- no longer updated
- Reauthor mode loses menus
DVD Rebuilder
+ Free and Pro versions
+ Ships with two quality free encoders (HCenc and Qenc) and a fast transcoder (Rejig)
+ integrates with CCE and Procoder
+ Still updated
+ High quality at higher levels of compression
+ Now has an installer so setup is simplified
- Reathoring in pro version only
- Uses a number of freeware components, so trouble shooting can be trickier
- Can sometime undersize discs for no reasonRead my blog here.
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
Noob DVD Rebuilder Question
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2008, 07:33 -
question about using DVD Rebuilder to compress 4 dvds into 1
By jimdagys in forum Newbie / General discussionsReplies: 20Last Post: 7th Jan 2008, 13:15 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20
