In some movies, it seems that the audio starts after the video.
I mean, when i play in bs player everything is ok... audio in sync with video, but i use nero vision express and when i see the preview the audio is out of sync with the video. please help...
Results 1 to 23 of 23
What's your source material? How do you process it from source file to finished DVD?
/Mats -
it's a avi file. open nero. create dvd. add files and when i see the preview the audio is out of sync.
Many encoders have problems with VBR audio - this could be the situation here. Also, many AVIs have bad frames and stuff that makes 'em almost impossible to convert to anything else, even if they play fine as AVI.
Try something besides Nero - divx2dvd seems like a popular choice for those who prefer oneclickwonder apps.
/Mats -
Did GSpot say anything about VBR audio?
Really, IMO, taking any AVI, dropping it onto some random AVI-to-DVD app, and expect it to come out without a hitch, is to be overly optimistic...
/Mats -
vbr audio? i don't understand... it sais that i have 3 compatible audio codecs.
I like nero because it permits to make a preview of audio, video and subtitles.
I'm sorry to bother you... -
That you get both audio and video (albeit out of sync) makes it clear that you have the required codecs.
VBR audio = Variable BitRate audio. Very nice and efficient, but a PITA when it comes packaged in an AVI, and you want to do anything with the AVI besides watching it. Unfortunately, very common.
/Mats -
130 kb/s (65/ch, stereo) VBR LAME3.96r¯
This is what i see in the audio bitrate window and
48000 Hz
is in the Fs window. -
For video, there are many encoders out there:
TMPGEnc, CCE, Mainconcept (commercial) quenc (free)
The "mixing" is done when authoring:
TMPGEnc DVD Author (doesn't support subtitles), DVD-Lab for commercial options, DVDAuthorGUI, GUI For DVDAuthor (free alternatives, both handle .srt subs IIRC)
There are many guides to read left under CONVERT for AVI to DVD, which may suggest different methods and tools.
/Mats -
I'm having an audio sync problem as well. It's after converting .wmv to mpeg2. What if the video has already been converted to mpeg2, would I have to start over from the source file (the wmv file) in order to fix the sync problem the way that was mentioned here?
Also after authoring to AC3 + m2v to dvd can I put the video/music file back to mpeg for menu creation?
You can use AC3 Delay Corrector to fix sync problems after encoding, assuming the problem is simply a delay issue. If the problem is caused by other issues - corruption, bad frames, format conversion - then you need to determine what the cause is before you can fix it.
If you authoring software cannot use elementary streams (i.e. must have an mpeg file) then get a new authoring tool.Read my blog here.
Hiya
Sorry to butt in but I have been trying to find this prog
AC3 Delay Corrector for a few days and the links seem to be broken. I have a couple projects I'd realy like to try it on . Web search just keeps takeing me to a german page that I can't readAny ideas of other sources for it?
Thanks !Everythings new till you try it once.... -
I had no probs folowing the link from the tools page - ended up with ac3d21b1.rar on my HDD.
/Mats -
I get to softpedia ok, but then both external mirrors (1 and 2) give me a file not found error, and the softpedia mirror bombs out looking for a local referer. This is in both FF and IE.
[edit] A google search turned up this though - http://www.free-codecs.com/download/AC3_Delay_Corrector.htm [/edit]Read my blog here.
Thanks guys! the last link on the page finaly went through and I just downloaded the rar . Will give it a try on the one project, prob will not help the other project as the file seems to have messedup and my sound is actualy longer then my movie. Starts out fine by the end its almost 3 sec out of sync!
Hurrah
I've just worked out how to do it. Had the same problems. Tried everything, then discovered this formula.
It'll only work for films that start in sync and go progressively out.
[film length(secs) + seconds out of sync]/ film length(secs) * playback rate
This gives you a new playback rate to change in goldwave. Change new playback rate and then resample back to original afterwards.
The resulting wav file should be in sync. The hardest bit is guessing how many seconds it's out at the end.
Thought it might help cos its being getting on my tits for ages.WOODY
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio out of sync after DVD authoring
By dexter30 in forum Authoring (DVD)Replies: 7Last Post: 29th Oct 2010, 18:27 -
Audio out of Sync with DVD Flick
By kawyboy in forum Video ConversionReplies: 1Last Post: 5th Apr 2010, 21:51 -
DVD to WMV - Audio out of sync.....Sometimes
By Number Six in forum DVD RippingReplies: 7Last Post: 14th Oct 2008, 19:19
