How do I join two VBR avi files?
I have tried using virtual dub and virtualdubmod and they both say that I have to extract the audio and encode to CBR.
If I do that then I will be reducing the audio quality. I want to avoid this if possible.
It shouldn't reduce the audio quality that much, but the audio files may get a little bigger. Just use a high enough bitrate.
Is there any other way to tackle the situation?
Would you recommend just putting them both into nerovision seperatley as VBR's and hoping that there are no sync issues? -
I can almost guarantee you there will be. Most apps do not like VBR MP3 audio. If you try to join them you will almost certainly get sync issues. If you just want a big AVI file, you should change them. If you run them through Nero vision it will re-encode them anyway, so you should do it on your terms, not Nero's.
Read my blog here.
VBR audio is a problem for most (all?) encoders.
You should avoid it at all costs.
That said, there's a special VDub build that's supposed to handle VBR audio - VirtualDub MP3 Freeze - try that.
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 08:35 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 03:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 13:22 -
joining avi files
By king2136 in forum Authoring (DVD)Replies: 4Last Post: 1st Oct 2007, 15:30 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 20:19
