Can you do multiple timer recorders on this system.I hate the tv guide and want to keep it simple if i can.But i noticed only one place to set the timers for television.Has anyone done more than one setting?
You can have up to 32 timer settings.
The easiest way to make a setting is to use the TIMER REC button on the remote. That takes you directly to the manual timer setting window. -
I have made one timer recording but how to i make consecutive timer recordings.
After you've made one, you can press the Home Menu button (or TIMER REC works too) to exit the settings window. Pressing TIMER REC again will start a new one.
As posted , use the remote initiate Schedule RecordingOriginally Posted by pantangs
In the lest side "Recorder Options", you can program the same show "Once, Weekly, Daily"
Display, Help and Info buttons on the remote expand the information for the scheduled recording.
After setting the time, channel, input, recorder, quality and frequency, "Schedule Recording". If you want to schedule another recording, use the Timer Rec button or Repeat the process. -
in order to get the tv guide to work do i need too plug in the cable with the quarter jack to the cable video box.In canada we have shaw cable so im wondering if i should hook it up.
I had to jump through houps to Stop the TV Guide from accessing the hard drive. All I do is manual record and timer record.
To use the TV Guide, you will need a signal to the 533. I think you can pass through the 533 if your Cable is RF.
Cable box >RF in on 533 >RF out of 533 > TV
Try having the channels Auto Program. IF the channels do not match what the TV guide shows, look for options (in TV Guide Setup) to use a different cable version.
Pioneer 533 DVD-R Burning Problem/Question
By tcfrerich in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2009, 13:03 -
No picture with Firewire connection to Pioneer 533 h
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Aug 2008, 16:10 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59 -
LG LRH-890 vs Pioneer DVR-550 - manual chapter points??
By Hookah_Bon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Jul 2007, 17:55 -
Pioneer DVR-531 TVGOS menu won't even come up anymore/can't manual record
By ibhay in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Jun 2007, 19:34
