I have a series of avi's coded in Xvid , witch all have problems with randomly appering blocks in the picture.
The movies are all sharp , so not at all blocked , but random blocks appear on some frames , aspecialy on moving edges ...
How do i get writh of this??
Dagger
Results 1 to 15 of 15
Try dropping them into VirtualDub or my preferred version VirtualDubMod and check for errors. You can also see the attributes of the file under 'File Information'.
It doesn't appear to be a codec problem, that's probably a reason Baldrick suggested trying VLC. But it may be low bitrate or errors in the file. -
probebly to low bitrate (virtualdub: 1059 data rate (0.45 % overhead))
So..... nothing to do about that then , o... well...
Thanks Dagger -
picture included .
The movie is mutch scharper but you get the idea of the blocks that appear...
Dagger -
Ok... fun thing is that mij hole season is corrupted
Nothing to to about it??
Dagger -
Are you using the xvid codec, or something like FFDShow ?
Have you defragged your HDD lately ?
Have you scanned your drive for errors ?Read my blog here.
Did you play your file from a CD-R ??? If yes, try copy them to your hard disk or check your cd-r for error with Nero cd/Dvd Speed or DvdInfoPro
My first tought was the xvid drivers i first had Koepi's driver pack , then the tsunami codac pack but still all the same.Originally Posted by guns1inger
Next i wil try to defrag and error check
Update: No change after defrag!
Sul8ter
DAgger -
Originally Posted by cd090580
No strait from my drive (e drive = Sata 160 gig maxtor)
Dagger -
Do episodes from other seasons have the same prob? Other Xvids?
Maybe you'll have to uninstall all those packs you've instaled. They are nothing but trouble. All you need is ffdshow and the XviD codec that comes with AutoGK.
Need help dealing with blocking
By drawar in forum Video ConversionReplies: 4Last Post: 15th Jun 2011, 04:04 -
Something is Blocking my Firewire
By tomer621 in forum Capturing and VCRReplies: 0Last Post: 5th Dec 2010, 04:14 -
DV capture problems - blocking
By SnoopyDad in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2010, 20:22 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03
