I have a 700mb .avi (xvid codec) file with ogg audio, basically what I want to do is trim the file size down a bit and encode the ogg audio to mp3.
I imported the file in virtualdub using avisynth. I chose two pass encoding, during the 1stpass the projected file size is approximately 80GB! Thinking it was an estimation error, I let virtualdub run it's course, sure enough within mins the output was already over 1GB and no where close to being complete.
I've successfully used avisynth and virtualdub to convert mpeg to avi using twopass encoding in the past, so what could be causing this oversize problem and is there a workaround?
Here are my setting for the xvid configuration:
Profile: AS @ L5
1st pass:
Motion search precision: 6 - Ultra High
VHQ Mode: 4 - Wide Search
checkmarked the following:
Use VHQ for bframes too
Use chroma motion
Turbo
VirtualDub defaults to uncompressed if you don't select a compression codec. Use Video -> Comrpession... to select the Xvid codec and set the parameters.
And OggVorbis is MORE compressed than MP3... It's as good as MP3Pro. So why would you want to downgrade?
Virtualdub / Avisynth problem - stumbling between joined clips
By Sebastian2011 in forum EditingReplies: 32Last Post: 5th Feb 2012, 15:17 -
StaxRip - oversize problem
By zacharias in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2010, 13:10 -
Avisynth + Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 21st Dec 2007, 05:57 -
Using avisynth instead of virtualdub?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Jul 2007, 10:23 -
Avisynth/VirtualDub - What am I missing?
By Seraphic- in forum EditingReplies: 11Last Post: 29th May 2007, 17:16
