  1. I got the new version SVCD2DVD (registered) an I want to author and burn two mpegs...
    The DVD is o.k, but there is only the first mpeg - the second is missing! I did it with quick DVD avi assets (my System: Win XP Prof)
    Something was written about "bad installation" - should I deinstall and reinstall the Programm?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Were the two avis in the same TitleSet? Can we see the log please?
  3. How can I post the log or send it? I's funny, I can't find a mistake in the log, but an the DVD is only the first MPG...
  4. Hi, here is the log link
    cu Sandor
  5. oh---
    I try it again - but it doesn't work...
    I'm too stupid...
  6. try opening up the logfile & copying/pasting it into your next message?
    Jan 2006
    I am having a problem with the program. The first time I used the program, I converted SVCD's to a DVD, they were NTSC. Now for my second attempt, I am using a SVCD in a PAL format. I continually receive an FFMPEG error (at or around 16% project completion). After pressing OK on the pop up box, the program acts like it is finishing up the project. After looking into the destination folder, I can see that the converted files are incomplete. I've tried uninstalling the program and reinstalling it, but this morning, I thought it was working and instead it shut down the computer at 40% completion, and upon rebooting, there are NO converted files in the destination file folder. What is up ???
    Any help would be appreciated. I hate that I paid for this and is only good for ONE burnt DVD disc.
    Thanks in advance,
    Raul
    raulyn @ gmail.com
    I am including my last log.
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.0
    Version: 2.0.2146.38069
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
    Executable size: 2.51 MB
    Executable size in bytes: 2642003
    Executable CreationTime: 11/17/2005 2:11:40 AM
    Executable LastWriteTime: 1/26/2006 11:04:26 PM
    Executable LastAccessTime: 1/28/2006 4:58:55 PM
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 511 MB
    Free Physical Memory: 157 MB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.96 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: VIA Technologies, Inc.
    Computer Model: KM266APro-835
    System Type: X86-based PC
    Computer Name: RAULYN
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    User Name: RAULYN\raul
    ***************************** Processor ****************************
    Manufacturer: AuthenticAMD
    Processor: AMD Athlon(tm) XP 3000+
    Description: x86 Family 6 Model 10 Stepping 0
    CPU Speed: 2.158GHz
    CPU FSB: 166MHz
    L2 Cache Size: 512 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT-05:00) Eastern Time (US & Canada)
    ****************************** VIDEO *******************************
    Name: ALL-IN-WONDER RADEON 7500
    Processor: RADEON 7500 Series AGP (0x5157)
    Mode: 1152 x 864 x 4294967296 colors
    Video Ram: 64.0 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 5.15 GB
    DeviceID: D:
    FileSystem: FAT32
    FreeSpace: 8.09 GB
    DeviceID: E:
    FileSystem: FAT32
    FreeSpace: 1.14 GB
    DeviceID: F:
    FileSystem: FAT32
    FreeSpace: 2.90 GB
    DeviceID: I:
    FileSystem: FAT32
    FreeSpace: 5.96 GB
    DeviceID: J:
    FileSystem: FAT32
    FreeSpace: 8.90 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <SVCD2DVD DateTime="1/28/2006 12:00:54 PM"><AssetSet><Asset ID="891ffda2-2abb-4bfb-a487-7cb53da3e28c" Path="D:\TRNSAMRCA" Filename="2.MPG" /><Asset ID="41689c48-bad8-4314-b6ec-492211e9da7f" Path="D:\TRNSAMRCA" Filename="1.MPG" /></AssetSet><DVDStructure><TitleSet Name="Transamerica" PostCmd="" MenuButtonType="0"><MenuButton X1="224" Y1="200" X2="499" Y2="249" FontFamily="Tahoma" FontSize="28" FontStyle="3">Transamerica</MenuButton><Title Name="1.MPG" AssetID="41689c48-bad8-4314-b6ec-492211e9da7f" MplexOffset="0" /><Title Name="2.MPG" AssetID="891ffda2-2abb-4bfb-a487-7cb53da3e28c" MplexOffset="0" /></TitleSet><DVDMenu TVStandard="NTSC" Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Documents and Settings\All Users\Documents\My Pictures\Sample Pictures\Sunset.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="D:\temp_dvd\Transamerica" InitialProjectFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play " Loop="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 15 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="False" PAL2NTSC="True" AVI2PASS="True" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="_NEC DVD_RW ND-3500AG" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="True" /></Settings></SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 794 MB
    file=D:\TRNSAMRCA\1.MPG
    FormatName=mpeg
    Num_Frames=73461
    DurationInSecs=2938
    Duration=00:48:58.4
    VideoCodec=mpeg2video
    Width=480
    Height=576
    Standard=PAL
    BitRate=2268
    AudioStreamCount=1
    Audio1SampleRate=48000
    Audio1Codec=mp2
    Audio1BitRate=192
    Audio2SampleRate=-1
    Audio2Codec=NULL
    Audio2BitRate=-1
    Processing 1.MPG
    12:00:54: Converting PAL to NTSC (SVCD Profile)
    Using low bitrate matrices
    12:00:55: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
    12:00:55: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    12:00:55: built on Nov 9 2005 11:51:11, gcc: 3.2.3 (mingw special 20030504-1)
    12:00:55: inputduration4logo: 48
    12:00:55: Input #0, mpeg, from 'D:\TRNSAMRCA\1.MPG':
    12:00:55: Duration: 00:48:58.4, start: 0.220000, bitrate: 2268 kb/s
    12:00:55: Stream #0.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 480x576, 2530 kb/s
    12:00:55: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 192 kb/s
    12:00:55: Output #0, dvd, to 'D:\TRNSAMRCA\1_S2D.mpg':
    12:00:55: Stream #0.0, 29.97 fps: Video: mpeg2video (hq), yuv420p, 480x480, q=1-31, 3000 kb/s
    12:00:55: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    12:00:55: Stream mapping:
    12:00:55: Stream #0.0 -> #0.0
    12:00:55: Stream #0.1 -> #0.1
    12:12:32: [mpeg2video @ 00725880]invalid mb type in I Frame at 11 24
    12:12:32: [mpeg2video @ 00725880]Warning MVs not available
    12:12:32: [mpeg2video @ 00725880]concealing 30 DC, 30 AC, 30 MV errors
    12:26:22: [mpeg2video @ 00725880]ac-tex damaged at 8 10
    12:26:22: [mpeg2video @ 00725880]Warning MVs not available
    12:26:22: [mpeg2video @ 00725880]concealing 30 DC, 30 AC, 30 MV errors
    12:33:29: video:881767kB audio:80366kB global headers:0kB muxing overhead 23.195351%
    File Size: 794 MB
    file=D:\TRNSAMRCA\2.MPG
    FormatName=mpeg
    Num_Frames=75326
    DurationInSecs=3013
    Duration=00:50:13.0
    Width=480
    Height=576
    Standard=PAL
    BitRate=2211
    AudioStreamCount=1
    Audio1Codec=mp2
    Audio1BitRate=192
    Audio2SampleRate=-1
    Audio2Codec=NULL
    Audio2BitRate=-1
    Processing 2.MPG
    12:33:29: Converting PAL to NTSC (SVCD Profile)
    12:33:30: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
    12:33:30: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    12:33:30: built on Nov 9 2005 11:51:11, gcc: 3.2.3 (mingw special 20030504-1)
    12:33:30: inputduration4logo: 50
    12:33:30: Input #0, mpeg, from 'D:\TRNSAMRCA\2.MPG':
    12:33:30: Duration: 00:50:13.0, start: 0.236000, bitrate: 2211 kb/s
    12:33:30: Stream #0.0[0x1e0], 25.00 fps: Video: mpeg2video, yuv420p, 480x576, 2530 kb/s
    12:33:30: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 192 kb/s
    12:33:30: Output #0, dvd, to 'D:\TRNSAMRCA\2_S2D.mpg':
    12:33:30: Stream #0.0, 29.97 fps: Video: mpeg2video (hq), yuv420p, 480x480, q=1-31, 3000 kb/s
    12:33:30: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    12:33:30: Stream mapping:
    12:33:30: Stream #0.0 -> #0.0
    12:33:30: Stream #0.1 -> #0.1
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Should have started a new thread.... however here is your issue stated and resolved:
    https://forum.videohelp.com/viewtopic.php?t=265207&highlight=dust
