  1. Hi....
    I have succesfully captured 2 movies to DVD and burned them...
    Both movies playes fine.
    The last one though has some flicker in the bottom picture not much, but enough to be annoying...
    Can it be removed???
    Regards Haribo
    Used Miglia Director´s Cut Scart for capturing
    And used imovie on my Mac for the edit...
    Nov 2005
    Someone more familiar with your setup may have a better answer, but it isn't uncommon for captures to have some corruption at the bottom of the video frame. Sometimes this can be cropped on capture -- otherwise it needs to be cropped in software, & is usually less painful done at the encoding stage. Encoding to mpg2 usually takes a very small bit of distortion at the edge of a frame and makes it worse.
