Hi and happy new year
MY CD ROM on my d drive is playing DVD's sound slightly slow , the model number is HL-DT-ST DVD-ROMGDR8163B, can anyone be of help please?
I don't know if there is enough info here, buit I hope there is
1) Is DMA enabled on the drive?
2) Is Digital Sound enabled on the drive?
3) Have you tried giving Windows Media Player 10 (or whatever application you use to play DVDs) higher priority using Task Manager? -
Hi DragonQ I am not sure how to enable DMA , could you please help?
To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel and let the OS reinstall it. This will usually take a reboot.
From there, if no luck, get back to us.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
video player that support "slow playing".
By bbchai in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2010, 01:23 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2009, 23:24 -
No sound when playing in DVD player
By blizzery in forum AudioReplies: 1Last Post: 28th Jul 2007, 18:35 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
