I wrote a routine based on the other "Disable Macrovision" Utility - I only re-wrote it to add it to my kit and see if it works with MMC 7.5 (the orig was C++ so I had to VB it)
the file patches just fine - looks right - runs a-ok but I don't have any macro vision anything to test it on... below is the warning file from the routine I based mine on!
I think this only helps you if your recording through VCR or something ... dunno - email me if you are willing to test it.
Disabling ATI Macrovision detection
"Macrovision" is a simple (but nevertheless patented) copy-prevention technique which is used on many commercial videotapes and pay-per-view TV channels. It works by manipulating the signal in a way which confuses most (though not all) VCRs, while displaying without problems on most (though not all) TVs. A typical symptom of trying to record a Macrovisioned signal on a consumer VCR is that the recording will get alternately brighter and darker, making it difficult to watch. You will also be bitten by Macrovision if you try to feed a video signal through a VCR on its way somewhere else (for example, if you want to connect your DVD player to your TV via your VCR).
Macrovision doesn't work at all on digital-video hardware like the ATI All-In-Wonder series. You'd think ATI would see this as a competitive advantage, but for some reason they wrote a Windows driver which specifically looks for the Macrovision signal and cripples video capture if it detects it. A typical symptom of trying to capture a Macrovisioned signal on an All-In-Wonder card is that the capture file will look fine for a while, and then suddenly the video will seem to "stick," with the last few frames repeating over and over.
The offending driver is called "atinmdxx.sys" on my machine. Properties|Version identifies it as "ATI Specialized MVD VBI Codec." VBI stands for Vertical Blanking Interval, where the primary Macrovision signal is found, and I suppose MVD stands for MacroVision Detection. Video capture won't work at all without this driver present, so you can't just delete it. But, as usual, it can be rendered harmless by changing a single conditional jump instruction to an unconditional jump. That's what the DisableATIMacrovisionDetection program does.
This program has many perfectly legal uses. Copyright law grants you broad freedom to make copies for personal use of a video that you have lawfully purchased. What is illegal under copyright law is distributing copies, not making copies. The corporations which use copy-prevention technologies don't care about your rights, and that's fine: they're not supposed to. Unfortunately, the democratic governments of the world, which are supposed to look out for your rights, have been negligent here: they haven't outlawed Macrovision or DVD encryption. Until that happens, you will have to make do with tools like this.
Usage
To use the patcher just run it. It will locate the appropriate driver automatically.
If that doesn't work you can try to locate the driver yourself. It should be called either "atinmdxx.sys" or "ativmdxx.sys". Once you've found it, drag it on top of the patching program's icon and it'll start up and patch it. (Be sure you're enabled "show hidden files" in Explorer, or you won't be able to see the driver file.)
You will probably have to reboot to activate the patched driver.
Caution
Unfortunately, the Macrovision detection driver loads at startup (at least in Windows 2000). If something goes awry, your system might no longer boot after running this program. In case you have problems, the patching program saves the original driver in a file with the ".ori" extension, in the same directory as the patched driver. You should be able to boot up in safe mode and replace the broken driver with the original one.
Compatibility
I have only tested this program with Windows 2000 and the All-In-Wonder 128 16MB.
This program definitely will not work under Windows 95, because the driver that I patch is not supported by Windows 95. I don't know if there's some other Macrovision detector on those platforms, but I used to capture with VirtualDub and the old VfW capture driver and I never had any problem with Macrovisioned tapes.
This program ought to work under Windows 98, ME, and Whistler, but I haven't tested it.
TV-Out
Along with checking its video input for Macrovision, the All-In-Wonder cards also apply Macrovision to the TV output (if it's enabled) when you play DVDs. This patch does not disable TV-Out Macrovision.
Legal
This program (source, executable and documentation) is in the public domain and comes with NO WARRANTY. Run it with the expectation that it'll crash your system; then you'll be pleasantly surprised when it doesn't.
your pal,
Stinky -
ok heres the deal, I just got the ATI radeon 64MB DDR VIVO for christmas and am new to this game, however, I have been trying to become familiar with your works. If I'm understanding you right, you would like someone to install your latest creation (which i just downloaded) and see if it eliminates the nasty macrovision (my personal nemesis
I have a pIII 667, 512MB running plain old win98--can I assist you in your endeavours in any way?
This was an old post
you can go to http://stinky.dosrules.com and get it (the patch is now part of the tool)
it works on NT/2K and XP ... I just learned today that it doesn't look in the right spot for 95/98 ...so I will probably update that in the next release
if you have 95/98 and you don't want to wait - just look inside the DisableMacrovision.zip in the toolyour pal,
Stinky -
Stinky,
I downloaded and ran your patch. I'm running Win 98. Sadly, it did not work. I saw the previous post and also put it in the win system folder, but that didn't help either (I did not have a copy there originally as the previous poster did). The tweeker runs just fine and I have no trouble capturing but Macrovision is still enabled. If you (or anyone else) has any ideas, I'd love to hear them.
Regards,
:( Iron -
Stinky,....
Thanks for the info. I was looking for a Macrovision tool,.. and so were many others.
I ran into this when I was setting up my little "Studio", with TV, VCR, 8mm camcorder, DVD (Apex), and my PC system. Not thinking about it and looking for the plugs, connectors, etc. to hook all this up to my ATI card I actually ran the composite output out of my DVD player into the VCR and then fed the VCR coax out to my TV. Of course when I played my DVD none of it would work,... as you described,.. I got all kinds of glitches, and the fading in and out of color. Once I correctly connected things, everything was much better. The little TV I'm using does not have a ""S" video input so I ran S video from the DVD to my ATI card and fed composite output to VCR and then on to TV. Sure fixed the problem.
Thanks again."Technology",...It's what keeps us all moving forward.
Problem with Running Vob2mpg under 'LionCamp'
By Doug Neale in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Sep 2011, 12:26 -
Problem running vob2mpg
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2010, 11:29 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
Problem ripping/copying Running with Scissors
By weflyrc in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Jun 2007, 00:12 -
DVD FLICK running problem
By gap0306 in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:54
