I have Nero Premium 7. I am trying to make a cover, and using some images to put into it (they are all JPEG/GIF format). If I go Insert->Image and then choose the image file, it is really small. If I then expand it to near the correct size, it becomes pixelated.
Why does it import images and make them really small and pixelated? If I import the same images into Word 2003, they appear the proper size and are not pixelated at all!
Any ideas?
Never used Nero Cover Designer, but I'm gonna guess your images are too small. It's not just pixels you have to worry about, you also need to have enought dpi. Use larger images. For a full DVD Case your image should be around 2140 x 1420 @ 200 dpi. If you have to resize up, You can use Irfanview (free). It's a great image app that everybody should have on their PC. You can resize up using the Lanczos Filter that does a very impressive job of enlarging your images.
Worst case, you can use Word to make your covers. I've actually used Excell to make a lot of CD case back covers that looked great.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Have you tried printing one to see if it actually prints pixelated? Could just be an issue with the software and it may print correctly.
Google is your Friend -
Originally Posted by dipstick
Tayo Yuden Printable and Nero cover design
By alexwick in forum MediaReplies: 5Last Post: 10th Oct 2011, 10:00 -
Images imported are the same.
By indosta in forum EditingReplies: 0Last Post: 6th Oct 2011, 10:07 -
Imported video goes narrow---Nero 8
By will7370 in forum EditingReplies: 2Last Post: 17th Aug 2011, 23:44 -
With Nero 7 Ultra, why are imported dvd files so big?
By wisny in forum EditingReplies: 13Last Post: 13th Mar 2011, 07:38 -
Nero Cover Designer
By kenmo in forum MediaReplies: 6Last Post: 25th Jan 2008, 09:43
