Hello!
I want to convert a Xvid 640X480 resolution with AC3 sound to DVD. I want as good quality as possible. Which method is best to use to get great quality??. I dont want any worse quality than whats in the original file!.
Also I want it to be able to handle subtitle files meaning converting text subs to DVD bitmap subs. Also chapter creation ever 5 minutes would be great!.
Will DivXToDVD be a good choice??
How fast is it at converting a 2 hour Xvid to DVD on a AMD Athlon XP 2600+ system that I am using??
I dont want it to take more then 4-5 hours!
I have heard that DivXToDVD is easy to use and very fast at converting. But this worries me if it is fast will it produce shitty video??. As said I want good quality video that are good enough for a 51" TV!.
Sincerely Joakim Agren!
Why bother with an all-in-one?
I would use TMPGEnc Plus and manually set everything as needed (bitrate, resolution, GOP, etc). I get to control everything.
Then I'd use TDA to author a menu-less disc.
Uses software most people already own, no reason to buy or install anything else.
Easy enough.Want my help? Ask here! (not via PM!)
If you are seekng "best quality" then walk away from DivxToDVD as fast as your legs can carry you.
Agree w/smuf, but would also add AVI2DVD, The Film Machine, & SVCD2DVD as conversion apps that can produce excellent results using included freeware encoders
Best possible quality XviD to DVD
By Mdoodm1000 in forum Authoring (DVD)Replies: 7Last Post: 9th Dec 2010, 09:01 -
Converting VHS to XviD - awful quality
By Zippy1970 in forum Video ConversionReplies: 26Last Post: 11th Sep 2008, 09:22 -
Quality loss in converting from DIVX to XVID?
By fwtong in forum DVD RippingReplies: 7Last Post: 25th Jan 2008, 17:37 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
How to get the Highest Quality from DVD -> xVid or whatever is better?
By mistafro in forum ffmpegX general discussionReplies: 10Last Post: 22nd Aug 2007, 13:25
