I need input on two issues with this recorder:
1. Burned DVD+R DL on Nero. Disc plays on my $30 DVD player, but, will not play on ES30V. Manual says cannot play DVD+R DL. Any inputs on how to get around it(any tricks in Nero etc..)
2. After firmware update, recorder now plays 16X DVD+R (verbatim), but, still will not record on 16X DVD+R. Any inputs appreciated.
I did the same thing some time ago. You need to change the booktype (also called bitsetting) of your burner to DVD-ROM. It's a good thing to change all your +R, +RW and +R DL settings to DVD-ROM. This should allow them to play on all players and drives. Unfortunately, this must be done before you burn, nothing you can do about the one you burned already.
You can change the settings with cd/dvdspeed, click Extra then Bitsetting, change then click set, check default and it will stay that way.I love children, girl children... about 16-40
W.C. Fields -
Because of the date of your post, you are probably using the latest firmware for the DMR-ES30VP (dated 9-DEC-2005). If this is the case your media may not be supported yet and you should continue using 8x media in the mean time.
With my DMR-E55 +DL is supported only if bit setting is configured to DVD-ROM -
Originally Posted by mbnI love children, girl children... about 16-40
W.C. Fields
Dual Layer Burning Issues
By bboy2448 in forum Newbie / General discussionsReplies: 13Last Post: 28th Sep 2010, 20:12 -
Panasonic ES30V Stopped Reading blank discs
By newshoes in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Oct 2007, 15:50 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 09:36 -
DVD dual layer help
By Dan206 in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 09:22
