I am having trouble keepin the files down to a reasonable size. Maybe the following questions will help me reduce any possible overkill.
1) What is the resolution that the Playstation2 puts out? I assume I would want to use the same amount.
2) Is the format I want to capture avi? I would then have to convert to either wmv or mpg? If converting to mpg with temp do I change the bitrate to change the filesize?
Well , I'm not the only one who dose them ...lol
My brother play's them while I sit back and record it on my pc , then encode to mpeg2 with ac3 audio for dvd later .
Had him going .. took him 3 minute's to realize what was happening .. he was watching the playback and couldn't figure out why he wasn't turning when he turned the race wheel ...
As for capturing to size , it depend's on hardware you have ..
You may have a capture device that support's encoding directly into dvd format ... it is possible to capture at higher screen resolution's on the pc using various screen capture tools ...
The one I use all the time is camstudio , size up the video preview window on the pc , something like 1200 x 1100 , set codec's , frame's per second , and let it rip ... though this entirely depend's on the pc ... the faster the cpu , the easier the task will be .
You can capture at normal rate to the pc , and upscale the video later ... but it's not worth it in the end if you are trying to get the file size down .
As for q1 , no you do not want to do that ... way too big .
As for q2 , Avi , compressed is going to give the best size , the only way to improve this is to downscale the video size ... say captured at 720x576 , resized down to 352x288 ...
Remind's me : 528mb dv1 produced from movie maker , converted by super using
output = 13.8mbs ... yes an mpeg1 with ac3 audio .
Converted this to xvid , shaved 1mb off .
Encode original dv1 to same spec's for xvid , same size in output ... just incase . -
1) Playstation 2 puts out same amount as NTSC signal... 525 x something?
2) Does your capture software do compression? Or just uncompressed dump? -
Thanks to all for the replies.
Its a PCI ATI-Tv-Wonder, Intel 4 2.4 GHZ system. The software I use is Virtual VCR, for some reason its the only one I can get to work.
It uses about 1GB per minute at 640 by 480 avi file.
So if I capture at a larger res and downsize it produces better quality than just going straigh to the final size? When I try capturing with compression such as Huffy the quality is seriously degraded. Alprasoft wasnt bad but now I get errors with it.
Capture flash video playing in a web browser?
By sdsumike619 in forum Capturing and VCRReplies: 2Last Post: 14th Nov 2010, 01:28 -
Any gurus here that know how to capture SWF from the web?
By sdsumike619 in forum Newbie / General discussionsReplies: 18Last Post: 6th Feb 2008, 22:53 -
how can I capture video from the web
By brew in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2007, 23:52 -
Converting to post clips on the web...what codec/format to use?
By FreeBaGeL in forum Video ConversionReplies: 3Last Post: 13th Sep 2007, 04:01 -
Trying to post video from my xbox 360 to my web site
By o2rustyw02 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 19:28
