Hi all, not sure if this has been covered but im looking to extract some audio from dvd vob files and convert to mp3 so i can play them on my car cd player.
im lookin for a decent programme to extract it and was wondering if nero could do it?
any help would be much appreciated . cheers
dvd audio extractor
Or demux with dvddecrypter and use besweet to convet the ac3 to mp3Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
depending on exactly what your doing, and if you want the ENTIRE audio track or not, you may also wanna consider going this route....rip the chapters (if its only segments of the dvd's audio) then load that up in dgindex and set the audio to demux whatever track it is you want.....it will spit out an ac3 or wav...or i think it even does mp2 depending on what was used in the origional....audio track for JUST that section...i used this method to take wav files off a dual disc cd, burn em to a data cd and play it back in my car stereo.....ended up with above cd quality audio playing back in my car stereo...
Yep, dvd audio extractor is an excellent program for getting audio off dvd's into pretty much any format you need.Originally Posted by yoda313
Or you can use dgindex to get a good .wav file and then convert that to mp3 as whitejremiah stated.
Mess with besweet and you'll just end up wanting to commit harakiri
Batch extraction of audio streams from mpg/vob?
By gaikokujinkyofusho in forum AudioReplies: 1Last Post: 4th Dec 2010, 05:15 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 16:56 -
Problem with Audio when playing VOB dvd files
By rbrown871 in forum AudioReplies: 9Last Post: 8th Dec 2008, 10:36 -
Dummy VOB, full disk extraction...cannot be done
By sknox in forum MacReplies: 11Last Post: 9th Oct 2007, 22:36
