I am in the midst of building a media PC - at the point where I have speced the obvious stuff - hard drives, cases, DVD drives etc. - but now I am getting to the tricky bit - graphics cards, sound cards, TV cards.
My choice seems to be determined by two main things : 1) what I actually want to do (duh !) and 2) What software I am going to run to achieve this.
My main requirements are -
1) Ability to watch one live TV channel whilst recording another (different) live channel
2) Elctronic program listing (for UK DVB-T transmissions)- integrated with the recording side of things
3) Pausing live TV
4) Storing TV/camcorder footage to DVD (so DVD is aplyable on standard set top DVD player)
5) Storing CD's - MP3's and transferring them to USB devices (portable MP3 players)
6) Ability to do several of the above at once (eg. record camcorder footage to hard disk/DVD whilst watching TV)
7) Idiot proof (My wife/dad/son need to use it --- Sorry !)
I know that I need two tuners (I would prefer DVB-T) or a dual tuner card - but I do not know if Microsoft Media Centre 2005 edition will let me do the above (their website is OK for beginners - but I cannot find a tech spec).
Any help on MCE 2005 capability in these areas would be greatly appreciated (I do not want to buy the wrong hardware/software).
Here's a list of capture cards that are MCE compatible from www.cnet.com:
http://reviews.search.com/search?q=mce&nodeid=8903&mode=products
As far as dvd burning, mp3 storage and usb capability that should be automatic. As long as the mce pc has a dvdrw drive and a usb port theres no reason you shouldn't be able to do all that like a standard pc.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I know I can do all this using standard XP apps ! The point is, can I do it all from the MCE2005 front end ? If I cannot, then there is no point in getting MCE2005 (the MCE 2005 front end is probably the only thing simple enough for wife/son to use).
It is very difficult to determine if you can do stuff simultaneously with MCE 2005 eg. recording a TV program is simple with MCE, so is uploading camcorder footage - but will the MCE front end let me do both at the same time ?
Can't get MCE 2005 to recognize vBox 3560
By frankmaster100 in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Dec 2009, 09:11 -
Hauppauge HVR-1600 HD tuner with MCE 2005
By rallynavvie in forum Media Center PC / MediaCentersReplies: 60Last Post: 29th Mar 2008, 14:22 -
Remotes dont work under MCE 2005
By Annex in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Jun 2007, 08:30 -
DVD/TV Decorder for MCE 2005 ?
By Datahead in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2007, 13:03 -
Decorder that works with MCE 2005?
By Datahead in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th May 2007, 12:57
