Hey
I wasn't sure where to put this, so I decided to put it here.
I was wondering how I can get that affect that karaokes have where the highlighted text is highlighting to the right of the screen. Is this possible with Adobe Premiere Pro? Thanks for any help, I am new to this.
Ok, here is my example. From a Thai karaoke, but that shouldnt matter. As long as this .gif animation demonstrates what I want to do in Adobe Premiere Pro. Oh by the way, can you also tell me how to do this in Macromedia Flash MX 2004?
I already started my karaoke in Adobe Premiere Pro and I'm REALLY close to finishing. Just I need to add the karaoke effect thing onto it and I would be done.
http://img.photobucket.com/albums/c192/animesmap/example.gif -
Unless the original text is using a separate layer, it's going to be a royal pain in the arse...
You'd need to recreate the text within Photoshop, (via exporting the frame from Premiere) and reimporing the Photoshop layer into Premiere...
From here, you can do a clip function on the newly aquired text, and chromakeying out the clipped area...
If there's anybody with a better suggestion, i'd gladly be all ears...
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Imprted to Adobe Premiere Pro CS5 from After Effect.
By indosta in forum EditingReplies: 4Last Post: 20th Sep 2011, 09:26 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Adobe Premiere Elements 4.0 Active Camera effect
By kingstinky in forum EditingReplies: 0Last Post: 4th Jan 2009, 18:22 -
Adobe Premier Pro 2 - Picture effect question
By flipzoso in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 22:54
