Results 1 to 11 of 11
  1. Hello
    I asked this question a few weeks ago and god a good answer but can'e find it as a trhead, as I ask again sorry
    how to you download and make sure you have a complete set of vids and what program on a mac do you use to rejoin the various segments and file typoes out there opn the web?
    thanks and sorry I can't find the original reply
    rotuts
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    Feb 2003
    Calgary, AB Canada
    After you've downloaded....
    These two will look through all the files and check that all the parts are there. If they aren't there, they'll rebuild them using the .par files if it can. Then recombine.
    MacPAR deLuxe
    UnRarX
    This one can only recombine (I think)
    MacHacha
    -- sdm
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    You can also use Stuffit 9.02 or later to unpack
    .rar segments, but yes for .par checking, and verification
    of valid segments, you need either Mac Par Deluxe
    ( *high reccomendation*)
    or UnRarX.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. thanks! one question: there are par2 and rar files, a series with the same name. are Both sets needed to make the movie or only the PAR2? or only the .rar?
    thanks for the tips
    rotuts
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  5. Member terryj's Avatar
    Think of it as this:
    The Par2 file is the Installer tome,
    the .rar are the chunks of the installer it must unpack
    to get your result, which is the movie file.
    You could force individually unpack the .rar, but if a .par2 is present,
    you should ALWAYS double click on that to get, say
    MacPar Deluxe, to verify that all pieces are valid,
    and then it will upack the .rars for you.
    Urban Mac User
  6. terr:
    Im still trying to learn about this. ive seem PAR2 files then mpg's in volure parts, then just the mpg as a stand alone file. if the file is a stand alone one, why have the PAR2 and the mpgs in volumes?
    isn't the idea of PAR2 and the mpg volumes to make a long movie into shorter parts that you then accumulate maybe between servers or over time?
    thanks rotut
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  7. Member terryj's Avatar
    The goal of Par2 is to enable
    ( *cough* cheap bastards on dial up *cough*#)
    for multi part segments that can be
    recombined from one or multiple servers,
    and then pieced back together to enable the
    one stand alone file.
    So for instance, if your on 56k ( god, i hope not) modem,
    and there is a 1.33GB mpeg-2 file standalone, and a
    Multi-RAR ( say 64 piece) archive with Par2 files
    (11 total) at a total of 1.37GBs,
    then you would want to download the
    Par2 and segmented .rar files, as you'd have
    a better chance of recieving the smaller files piecemeal,
    with less chance of data corruption, than you would
    the whole COMPLETE file, which 80% of the time
    gets corrupted on a 56k modem download, in some
    form or fashion.
    if a Par2/segmented RAR archive gets corrupted over
    56k download, then you could easily patch/repair the:
    missing segments
    hosed segments
    corrupted ( by bits) segments
    And have a complete working copy of the end
    MPG-2 file after fixing.
    If you try and download the whole standalone on 56k,
    you could:
    get cut off in the download
    get a corrupted segment of data, with no way to fix it
    get an incomplete download, and then have to start all over again.
    If you are on broadband, you would want to get the
    file either via torrent,
    or you could do the standalone, provided your not
    on a capped download
    cycle ( 1MB, 2 MB, or 3 MB).
    Doing it via Torrent would insure a faster transfer
    per your connection, and less of a chance of data corruption.
    (# I apologize in advance to any who may resemble or take offense to this remark.)
    Urban Mac User
  8. Terr
    thanks for the carefully thought out reply. as I now have DSL which is cheaper than my dial up Im trying tolear about these segs.
    but how do you know about all the parts in either PAR2 or rar before you aattmemt the download? is there a specific info file you look for? then save that and look for the pieces?
    what is torrent? I verison DSL and I guess have to go through them?
    thanks
    rotut
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  9. Member terryj's Avatar
    rotus, good to know on the DSL thing...
    1. In many cases, a reputable poster would include a
    .NFO file (a text file used to denote iNFOrmation of
    an archive), which would tell you how many segments,
    how many rar's, etc with the segments to download.
    That's the file you look for.
    However many do not, and the only way then to tell at
    that point, is to use a program like UnRARX or my fav,
    MacParDelxue, which when it reads the Par2 file, will
    extract that info to match up the contents of what
    you downloaded.
    if a file is missing a segment, then the program will note
    that and try to recover it. If there are too many missing
    or corrupted segments, it will tell you it cannot restore.
    2. go here and read up on Torrent:
    Torrents
    Urban Mac User
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    rotuts: use the search and search for you username if you can't find old posts...or click on "View your posts" on the forum index page...
  11. bald
    thanks for the tip but I tried that and couldn't find my posts. I also no longer can automatically log in when I go to the forum so something might be screwey with my browser. Im using mozilla and its funky on the cookies for some reason and thats new
    glad to see you are a blackadder fan. I has all the dvds out from the library a while ago a fine program
    rotuts
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
