Hello, what's wrong with this picture?
The .mpa audio file plays good on a Windows Media Player!
Even when I tried to mux them using ImagoMPEG, it again complained about this same .mpa file!
Original Avi file is NTSC 23.976fps, PCM audio, 48kHz
C:\>"F:\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "F:\DVD2SVCD\Movie\MPlex_Muxed_File00.mpg" "F:\DVD2SVCD\Movie\Encoded_Video_TMPGEnc_NTSC. mpv" "F:\DVD2SVCD\Movie\Encoded_audio_1.mpa"
INFO: [???] mplex version 2.0.0 (dvd2svcd modified) (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File F:\DVD2SVCD\Movie.Napoleon\Encoded_Video_TMPGEnc_N TSC.mpv looks like an MPEG Video stream.
**ERROR: [???] File unrecogniseable!
**ERROR: [???] Unrecogniseable file(s)... exiting.
Thanks.
I don't use dvd2svcd, but they do have their own forums for troubleshooting.
For whatever reason, the file appears to be corrupt or not in a format that it is expecting.
Try opening the file in a dedicated audio program such as Goldwave, then converting and saving into a different format (or even the same format).Google is your Friend -
IIRC, SVCD's audio is
44100 Hz
32 - 384 kbit/sec MPEG-1 Layer2 or MPEG2 Audio
with up to 2 Audio Tracks
Adding a second audio track to the exiting DVD movie
By benwong in forum Authoring (DVD)Replies: 13Last Post: 11th Sep 2012, 03:32 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
PC DVD Player that support resume after exiting
By csc12345678 in forum Software PlayingReplies: 5Last Post: 27th Sep 2009, 10:33 -
Exiting SVCD2DVD During Author without Warning
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:22 -
"dropping too many frames - exiting" muxing error
By ecc in forum Video ConversionReplies: 0Last Post: 30th Nov 2007, 09:03
