  1. Member Mr anderson's Avatar
    Jan 2004
    Hi hope you all had a nice chrimbo & a good new year, my bro has a gamecube, now the red lef light on the top comes on then turns off within seconds of coming on? looked @ their website they said it needs to be fixed. anyway else had this prob, and can it be fixed?
  2. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    When you get "repairs" at Nintendo; they just send you a rerurbished system. Their refurbs are really good though. Probably much cheaper than buying a new or used system anywhere else.
    Or if you can wait you could just wait for the Revolution, but Zelda is coming soon. Suposedly the Revolution will play all of the Gamecube games. And it also has ports for four Gamecube controllers.
    I had my NES "repaired". They cleaned all of my cartridges and I got a working NES with the door on the front.
    Call their number and find out how much it costs. Also they have a one year warranty that they are fairly flexible with.
    They really wanna keep you playing and keep you buying games.
    I am suprised the other console makers don't have the same outlook.
    Also they will most likely want you to send in your controllers and most likely they will "repair" the controllers by sending you new ones.
    snappy phrase
    I don't know what you're talking about.
    Mar 2003
    Sounds like something might be wrong with the power supply or mobo
    here is a place you can buy a guide but after you buy the guide and parts it would probably be cheaper to buy a new one
    http://www.ultimateconsoleguides.com/gamecube.htm
    I have never worked on gamecubes but I have worked on tons of ps2s and xboxes
    Most of the time its cheaper to just get a new ps2 now for people to have me work on it an pay for parts to fix it but the xbox repair business is going well (in spirts)
  4. Member Mr anderson's Avatar
    Jan 2004
    thnx, but guess what, i just took the control pads out and now it works, one of them was some how killing the gamecube. so ive took the dead one out and kept the working ones? ive never seen something like that b4?
    Mar 2003
    Weird
    Glad its working now though
  6. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    my n64 used to do that too
